Need better MPG, Power, Torque
Discussion in 'Expediter and Hot Shot Trucking Forum' started by HSS RIG, Aug 20, 2015.
  1. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    In normal circumstance, i agree, and thank you...
    He lost my dirtbike off a mountain high on heineken, he laughed and laughed...got up off his butt and laughed some more, and says' well I guess i owe you a dirtbike', this 8 years ago...makes six digits too
    So, I might not...I want to destroy his tires, not his motor
    Not because im a decent guy, but because I fear karma in general!! LOL
    Whatever works right?
    lots of character and truckon Thank this.
  3. AModelCat
    145,376
    I have one in a '13 F550 at work. I found it suffers from a serious lack of balls until the turbo spools. Then it seems decent. Never seen it make more than about 20 lbs of boost either.
    truckon Thanks this.
  4. stammingerr
    stammingerr Bobtail Member
    39
    5
    Aug 6, 2014
    Your 13 F550 is detuned. They are around 300hp and 650 torque. Where stock the 13 is 400hp and 800 torque.
    AModelCat Thanks this.
  5. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    I know you are on to it, but I think they like having a big pickup truck. I know I had a N14 that got 11 miles to the gallon when I hauled 40,000lbs and under. How that cant be better then the pickups MPG is way beyond me. :confused:
    KANSAS TRANSIT Thanks this.
  6. aussiejosh
    aussiejosh Road Train Member
    4,657
    5,282
    Aug 28, 2009
    Airlie Beach QLd
    If your running at 75 -80 mph you will naturally consume more fuel cutting back to 65 or even 60 will give you more miles per gallon ideally you need a engine with more horsepower that will also give you great mileage kind of a rare commodity there days.
  7. truckon
    truckon Swamp Thing
    4,775
    15,914
    Dec 16, 2011
    Like I'd tell you!
    Each has there place. Its not understanding the right place that people have a problem with.
  8. paheavyhauler
    paheavyhauler Bobtail Member
    10
    5
    May 16, 2015
    If going through pa on 81 stop by liberator performance
  9. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    954
    2,558
    Sep 15, 2011
    Cibolo,Texas
    The 6.4 powerstroke makes so much power with a tuner alone that other motors would need parts upgraded to even get close.H&S performance makes a tuner and so does SCT.check out the guys at powerstroke.org they can steer you in the right direction for tuning.
  10. Dustinx24
    Dustinx24 Bobtail Member
    4
    Oct 8, 2015
    Tune, exhaust, aftermarket intake, bullet proof it. 6.4 are known for putting 550hp to the ground with few mods...just hope the torque converter holds
  11. rookiedoorbumper
    rookiedoorbumper Light Load Member
    72
    8
    Aug 27, 2015
    NJ
    Rig the 6.4 has had problems with carbon buildup in the turbo vanes causing weak boost and poor mpg because the variable geometry turbo doesn't work properly
