Hello, I Have An 08 International Pro Star.
My Horn Stopped Working, I Have Checked The Horn Solenoid, Pulled The Black Hose Out And Tried The Horn No Air Comes Out, I Even Bought New Solenoid And New Horn. Still The Same Problem. And Now My Air Suspension Doesnt Work And My PDL. Anyone Have This Problem?
Any help Suggestions Would Be Appreciated.
Thanks.
Need Help 2008 International Horn Problem
Discussion in 'International Forum' started by Maksim Baranyuk, Aug 4, 2015.
Check fuse for chassis solenoids in fuse box or something in those lines solenoids not getting power to side of chassis either that or switches not getting power most likely burned fuse
Those are all controlled by an air solenoid pack next to the transmission on the left frame rail. The body controller sends power to each solenoid as you command each device. They all share a common ground. I would say the common ground is bad. Make sure the white wire at the connector has a good ground.
QUALITYTRUCK Thanks this. -
ok Thanks
