Give you a run down of the truck first.
2004 FLD Classic
14L Detroit with EGR less than 200,000 on rebuild
18 Speed
RD 23-160 rears was 4:30 upgraded to RD 23-160 3:73 Memorial weekend
Shifting gears no higher than 1700 rpm
Now here's my issue I bought the truck and was getting 4.5 - 4.7 mpg running highway turning 1700-2000 rpm with the 4:30's Upgraded to 3:73's to bring the rpms down and save fuel now running 1400-1700 rpm on the same runs now I have dropped to 4.0 - 4.3 fuel mileage went in the wrong direction.
Need help poor fuel milage
Discussion in 'Freightliner Forum' started by McDaniel Trucking, Jun 2, 2015.
You have a turbo boost meter installed? I have one in the heap I'm driving now, and it really helps with saving fuel if you use it right. I try to keep it at around 15 psi or less if I can help it. Sure, everyone at the truck stop is going to talk smack about how they ran rings around you, but you'll be the guy at the end of the counter counting that extra $200 he didn't have to spend at the fuel lane.
tallmon Thanks this. -
yup pulling hills 40-50 psi running down the highway 30 psi
Shaggy76 Thanks this.
Turbo is a VGT replaced gauge in March according to Detroit dealer turbo pressure is correct for this motor with the EGR and VGT.
Is it a mechanical gauge?
If you are showing 30psi while cruising, then you have a problem. The more pressure while running, the more fuel you use.
Start with checking the air path from the turbo to the engine for restrictions and/or air leaks.mhyn and tech10171968 Thank this. -
Sounds like you are getting pressure from the EGR being closed when it should open up. A bad EGR being stuck closed can cause as bad fuel mileage as one being stuck open. Stuck open you lose power and stuck closed you are over boosting, which is what your engine is doing, which is causing the fuel to dump more because the engine is reading the boost being high.
Check your EGR operation.
Sit in the truck with key off. Start the truck. Wait for air pressure to build and listen for the turbo to start its spool up at idle. This indicated the EGR is in a partial closed state, but still allowing the gases to go through.
Now rev the engine 3 times. Not slow, but like you are sitting at a stop light revving your engine to race someone. Listen to the engine and you will hear the turbo unspool and the high whine should go away completely. Your EGR is now in full open state. Look at the exhaust and watch it. It will have a very small haze of color. The engine will go back to its regular idle state in a minute or two and you should see the smoke go to clear. If you are not getting the slight smoke during this time, your EGR valve isn't opening up fully and then is needs to be checked into further.
Technicians will do the same stap with a computer while recording for playback to see what the pressures are reading on the Delta P sensor and the boost sensor. There are specs for those to indicate the EGR is functioning properly or not before needing to change it out.
The EGR doesn't have a sensor on it. It is only commanded and the computer doesn't know what the EGR state is. It can only determine that by the pressures it is reading on the Delta P sensor. You can have the beginning stages of a full EGR failure and not have a code, yet. You see this a lot on the 2007 EPA engines and the dpf filter plugs up quicker than normal. -
ddrs or dddl will show the problem quick...
