Greetings,
Need help with a DOT regulation.
I currently am operating a tri axle trailer. I lost a wheel bearing yesterday that destroyed the spindle.
I am being told that I am legal to remove the tires and chain up the damaged axle and still operate until I can get back home to repair it? I know not to exceed the remaining two axles weight limits.
Sure would appreciate the actual DOT regulation stating that I can do this because one DOT officer will tell me I can and the next will tell me I can’t.
Thanks for any help.
Dale
Discussion in 'Expediter and Hot Shot Trucking Forum' started by mackzar, Apr 30, 2016.
Let me get this straight, you want to haul freight like that? Two words, HELL NO! to limp off the hwy to a shop, yes.
OP what axle did you lose the bearing on??flood Thanks this. -
I see nothing wrong with doing as you say while staying within the limits of the remaining axles, EXCEPT; since you lost one bearing and axle, who is to say the others are not going fail in the immediate future without an inspection to insure their integrity?
I would be getting it repaired and the remaining axles inspected, ASAP! -
see it all the time at some of the auto plants
loads don't weigh much so they just chain up 1 axel
