Peterbilt fuel tanks GRRRRRR
Discussion in 'Peterbilt Forum' started by Rat, Jan 20, 2009.
  1. Rat
    Rat Road Train Member
    1,515
    Thanks Received:
    1,423
    Aug 31, 2008
    Rats nest Grafton North Dakota
    I have been running an 04 379 Peterbilt C15 MBN 475. 120 gallon tanks.
    The problem is the thing keeps pumping fuel from one tank and over filling the other. The shop has replaced both splitters and checked the ventlines and fuel lines but they can not find anything that is causing this.
    It was not really a problem before but they just installed a third lift axle on it and had to cut 11 inches off the tanks.
    Before I just did not fill the tanks to the top. I would run around with 3/4 to 1/2 a load of fuel and it did not actually over fill the tank. Now I have alot less capacity and need to fill this thing up. I refuse to fuel in the morning only to have to stop and fuel again in the afternoon.
    I tried to get the company shop to install simple hose from one tank to the other to keep the fuel levels in check but they refuse to do it especially in the winter because they say the line will freeze.
  2. Peanut Butter
    Peanut Butter Road Train Member
    1,337
    Thanks Received:
    409
    Nov 24, 2007
    PO Dunk Idaho
    The check valve on the fuel line maybe be bad, i had a kenworth W900L that did that but only when topped out on the speedometer, the truck was set at 70 mph, if i topped out at 70 the fuel went from one tank to the other, but if i kept it at 68 mph it didnt do that, i was told the check valve was at fault for this. anyways thought i would try to help.
  3. C16KIWI
    C16KIWI Medium Load Member
    579
    Thanks Received:
    137
    Jun 14, 2008
    New Zealand
    My T600 used to do this when I took the 3406C out and put the E in I just put a bigger hose in between the tanks.
    With the Western Star it has no cross over hose,the fuel pick up and return splits and feeds both tanks have had no problems,also I think its better at keeping the fuel cooler.
  4. pullingtrucker
    pullingtrucker Road Train Member
    1,189
    Thanks Received:
    553
    Dec 21, 2008
    Fostoria, Ohio
    The correct solution would be the crossover hose that the shop won't install. i have never had mine "freeze" either. If you treat the fuel the way you are suppose to and with the hot fuel return that line will never gel. I would check the vents on the left tank. It sounds like that tank may be getting pressurized and causing the fuel to be pushed to the right. Also if you do have the splitter valve that maybe a problem also. They are known for going bad. I would replace the splitter valve with a new one or a Y fitting if the vent is fine.
    Lil Shoe Thanks this.
  5. Sportster2000
    Sportster2000 Road Train Member
    1,207
    Thanks Received:
    368
    Jan 5, 2008
    Indiana
    We had this same issue on a 1995 pete 377. We replace the cross over line twice and it did not help. So I crawled under the truck in a parking lot in MO on an old mechanics advice and took a look at the return line. It had a small dip in it very similar to a sink trap under a sink. That sink trap had caused enough pressure to make all of the fuel return to the other tank. I zip tied the line up so that there was not a sink trap in it and I have not had a problem since.
    Brickhauler and stranger Thank this.
  6. Rat
    1,515
    Thanks Received:
    1,423
    Aug 31, 2008
    Well they replaced the splitter on it about a month ago.
    Today it worked fine but I turned the return line valve on the right tank down to half open and left it there. I am going to run it like that for awhile and see what happens.
    On a positive note. I got 4 mpg today and I bucked some wind and some serious hills. This was grossing 96,850.
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,719
    Thanks Received:
    1,972
    Dec 17, 2008
    If I remember correctly Pete changed the GT Equalizing valve to a T fitting at about the time your truck was built. For some reason the fuel gets to the T fitting and decides to flow only in one direction...........try replacing the T fitting with a GT equalizing valve. Make sure you have a T fitting in there now, before doing this changer.
  8. Les2
    Les2 Road Train Member
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    kicked back in my lazyboy...
    Your happy about 4mpg? Dang I'd be PO'd if thats all I got!
  9. Mr. Haney
    2,719
    Thanks Received:
    1,972
    Dec 17, 2008
    It's a bridge motor.............they get very bad fuel mileage to start with
  10. Rat
    1,515
    Thanks Received:
    1,423
    Aug 31, 2008
    Considering that the best it has ever gotten was about 3.5 then I am happy.
  • Draft saved Draft deleted
