Peterbilt vs. Freightliner weight difference and fuel mileage
Discussion in 'Ask An Owner Operator' started by lawrence1, Jan 22, 2008.
  1. lawrence1
    lawrence1 Bobtail Member
    Thanks Received:
    Jan 22, 2008
    Sacramento, CA
    I'm planning to buy my own truck and i'm torn between a freightliner columbia 120 and a peterbilt 387. I like the peterbilt more and it seems like it is a better buy at only $3k more than the FL but i'm concerned that it will be too heavy for pulling a 53' reefer.
    The specs on both trucks are nearly identical in their equipment and mileage(both at 460k miles) is very similar.
    here are the specs for both trucks:
    C-15 CAT 475hp
    10 speed
    100 gal tanks on peterbilt/110 gal tanks on FL
    a/s fifth wheel
    raised roof condo sleepers 70"+
    double bunks
    The pete's wheelbase is ~10 inches longer i beleive
    The reefer is going to be a 2001 or 2002 53' Utility with either a thermoking or carrier unit.(is one heavier than the other?). Is the Peterbilt going to work for all possible reefer loads? If not what would be a scenario that would not work with this configuration?
    also what kind of fuel mileage are you guys getting in the real world with these specs?
    thanks in advance.:biggrin_25514:
  2. Working Class Patriot
    Working Class Patriot Road Train Member
    12,587
    Thanks Received:
    23,088
    Jan 17, 2008
    Wherever and Whenever...
    I don't know about pulling refers with the Pete or the FL, but I do know that quite a few dump conversion guys like FL's because they're lighter, especially for Super Tens. Me personally, I wouldn't own anything other than a Pete or KW. My preference, and I am sure there are quite a few FL fans out there. Paccar just makes a better over all product IMHO:biggrin_2559:
  3. RNGTransport
    RNGTransport Light Load Member
    134
    Thanks Received:
    19
    Jul 13, 2007
    Allendale, MI
    My best guess is that the century is going to be a tad lighter but not much. You will have to be careful with all loads they are not all going to be legal no matter what truck you get. If weight is the only factor try asking them to test drive the trucks and weigh them. Try and calculate how much the fuel will add and go from there.
  4. broncrider
    broncrider Road Train Member
    1,605
    Thanks Received:
    3,148
    Mar 23, 2007
    somewhere drinkin beer probaly.....
    have dealer get the empty wieghts off the drivers door info sticker...then add fuel wieght...i.e...100 gallons x 8lbs per gallon=800lbs
    i dont think it will matter one way or the other...your lookin at about 34k empty with full tanks either way...but go with the pete for better resale and a MUCH better truck
  5. Eskimo6804
    Eskimo6804 Heavy Load Member
    816
    Thanks Received:
    3,323
    Jun 13, 2007
    Northeast Alabama
    With a 53 foot reefer, the empty weight would be more like 36k. I know with one of our 2007 KW T600's with 86" studio sleeper and a 2004 Great Dane reefer with a TK SBIII whisper unit, our empty weight is 37200.
  6. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,916
    Thanks Received:
    12,105
    Sep 17, 2006
    WY
    Did you mean 37,200? Other wise how do you haul enough product to pay?
  7. Eskimo6804
    816
    Thanks Received:
    3,323
    Jun 13, 2007
    Northeast Alabama
    you are absolutely righht Brick. dang brainfarts...lol
  8. Brickman
    12,916
    Thanks Received:
    12,105
    Sep 17, 2006
    WY
  9. RNGTransport
    134
    Thanks Received:
    19
    Jul 13, 2007
    Allendale, MI
    I can haul 43k with my WesternStar full of fuel hauling a 53' reefer. The company has a few lightweight composite reefers running supersingles and I can load around 44.5k on those.
  10. lawrence1
    Thanks Received:
    Jan 22, 2008
    Sacramento, CA
    alright so it should not be a huge different in between the 2. Thanks alot for your replies.
    One more question ... what are your throughts on carrier units? are they not as good and reliable as the thermoking stuff?
    thanks.:biggrin_25514:
  • Draft saved Draft deleted
