Problem with road noise-static
Discussion in 'CB Radio Forum' started by jammer 463, Jan 11, 2016.
  1. jammer 463
    jammer 463 Bobtail Member
    6
    I drive a 2004 Mack vision and I'm experiencing high levels of what I call white noise -static coming thru my radio at highway speed,when I slow down or stop the noise level goes back down to a normal level, anyone else ever have a problem like this ? Any Solutions ? Thanks
  3. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Sounds like a bad ground, or maybe even a alternator acting up, tho ground is more probable.
  4. jammer 463
    6
    The alternator was just replaced so I don't thing that's the problem, I to thing it's something to do with the ground but I have no idea how to go about solving the problem
  5. Fajo
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Start checking grounds around the truck, make sure none have snapped, they are pretty easy to spot.
    Also was this noise happening before the alt change or after ? You can check the ground to it also. If it happend after the alt was changed either the ground is loose if it's a really cheap alt they are not normally shielded that well either.
    jammer 463 Thanks this.
  6. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Where is it grounded through? Wiring harness? I've always grounded to the chassis or even the negative on the battery terminal. Never had any problems doing it that way.
  7. handlebar
    handlebar Heavy Load Member
    Some folks have put conductive grease in the wheel bearings, so that noise generated on the frame can ground out through the tires as you move. Also, not all tires are built out of conductive rubber compounds, so you end up riding around on a huge, insulated static generator. Conductive ground straps hanging from frame to roadway *may* help.
    Are you pretty sure it isn't related to injector pumps and the engine control module(s)?
    If it were a private vehicle, and I could find a stretch of road where I could safely put the car into Mexican Overdrive, I'd do that, listen for noise, and if still there, shut off the ignition, continuing to coast. If it's related to the engine running, it's likely RF noise generated in the form of either sparks or pulses from the stuff under the hood.
    Otherwise, I'm out'a ideas. You could always try disconnecting the antenna lead and see if the noise all goes away. If not, then it's coming in from your power leads. If the noise quits, then something on or in the vehicle is acting like a tiny RF noise generator and your radio is picking it up through the antenna circuit, like any other radio signal.
    73
    EZ Money and jammer 463 Thank this.
  8. jammer 463
    6
    It was doing it before and after to change, thanks
  9. jammer 463
    6
    Thanks handlebar, I'm thinking its a cheap tire thing myself, just wanted some input, if I try a ground wire would i mount it on the frame or the cab(being its an air ride cab)?
  10. Ridgeline
    22,176
    113,784
    Take some old bungy cords and hang them from the frame so they touch the ground, some put the on the steps. See what happens with that.
    jammer 463 and rabbiporkchop Thank this.
  11. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    Sounds like a ground loop. needs to be isolated
