Rent a truck/trailer?
Discussion in 'Experienced Truckers' Advice' started by IROCUBabe, Sep 23, 2009.
  1. IROCUBabe
    IROCUBabe Road Train Member
    2,565
    Thanks Received:
    1,012
    Apr 9, 2008
    Dallas, TX
    Anyone know a place where one can rent a MANUAL 18 wheeler with a trailer for a short period of time, say a day?
  2. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    9,988
    Thanks Received:
    6,856
    Jul 15, 2007
    TEXAS
    Not sure about Dallas but here on the north end of Waco(Bellmead). Across the street from DPS testing office, they have a truck w/trailer for rent. It is a day cab w/trailer (18 wheels). The trailer appears to be 48'. If your interested, I could write the number down for you.
    The only other suggestion I have is, call Penske or Ryder. I know they rent class 8 trucks but don't know the terms.
  3. GasHauler
    5,803
    Thanks Received:
    3,712
    Oct 23, 2005
    Vegas/Jersey
    The terms with Ryder are tough. You have to be qualified and you need the cash. I used to rent just the tractor and I would flop down $10,000 in cash and they used that for an account. Of course I was out for long periods of time but I do not think they would rent a tractor for one day and I'm sure they do not rent trailers. The trailers are mostly set up for lease and not rentals. Sorry. It sounds like the best way to go is renting a private set up and just make sure it will pass inspection.
  4. MM71
    MM71 Medium Load Member
    303
    Thanks Received:
    164
    Jun 28, 2008
    AZ
    Uh, in arizona ryder will rent a tractor for a day ... and a trailer for a day. But gas hauler is right, you better have a credit card with a serious limit. AND take some lube with ya, when they bend you over it really hurts.
    Penske is the same way. If ryder or penske only have power units available you probably have lots of trailer options in your area, ie xtra lease, national, pmi. Again be ready to pony up a retarded amount of money for a security deposit
  5. IROCUBabe
    2,565
    Thanks Received:
    1,012
    Apr 9, 2008
    Dallas, TX
    The day cab deal would be fine if you could get the number that would be worth the drive, I need to spend a few hours driving around to prepare for my next road test, and the schools crappy trucks and lot just will not work.
  6. crazyray
    crazyray Bobtail Member
    43
    Thanks Received:
    Oct 27, 2007
    arcadia LA
    followed some of your adventures in the past, best of luck with the new gig
  • Draft saved Draft deleted
