I bought a 2004 Freightliner Centry with 14-l detroit Runs great starts fine when engine is turned off and restarted. If it sits over night it takes long time to start. Runs fine after get started. Thanks
Starting problems 60 series Detroit
Discussion in 'Freightliner Forum' started by Texasshorty, Jan 14, 2012.
Check valve in the rear of the head.
Thanks that answered my question. Have a nice day
Ed -
Any idea the name of this valve. Thanks
I was told that it is a fuel check valve it keeps the fuel from draining back to the fuel tank
its called a fuel check valve. there is one on ebay thats cheap
The fuel check valve is not going to fix it. Does it start with either? Sends a srs sensor code to ecm?
I believe I'm having the same problem. The starting difficulty gets worse, eventually it will only start with either. Does this sound familiar ?
Not having starting issues, but do have the SRS issue. It will surge under high idle and accelleration.....anyone else experiencing this?
There's also an inlet check ball on the fuel filter. I've found trash in there letting fuel siphon back to the tank after sitting a while.
