The first step to building a mobile antenna for a tractor is knowing what your height restriction is and knowing your mounting location and that will tell you how long it can be physically.
It's unfortunate that not too many antenna Builders use that way of thinking and they end up building antennas too long or Too Short
top load vs center load antenna
Discussion in 'CB Radio Forum' started by fgb3, Dec 18, 2011.
Page 9 of 17
talk about. doesn't matter top loaded/bottom loaded whatever. a key down antenna will out perform any of these antennas talked about on here....on a field strength meter a key down antenna will blow all these antennas away top loaded/bottom loaded whatever. look at a big John fat boy antenna and how long the stinger is. and make that work on a trk.
n fat boy antenna and how long -
Because yer everyday trucker isn't keying down?
Let me simplify for you. The tallest antenna you can run on your truck implies explicitly 13' 6" max. Only an idiot would think otherwise, and you.Highwayman1224 and rabbiporkchop Thank this. -
Well, I am over 60 with about 4 million miles under my belt, I might be ready for diapers again real soon, you may have a point there. But as far as the best goes..... I think I know a thing or two about that.
Page 9 of 17
