Advice from the TTR Judges.
A couple weeks or so ago.
I was leaving the Pilot in Dickson, TN.
Before you turn back on the Main Road
There is a Stop Sign.
RR Tracks
And another Stop sign closer to the main road.
Some of you guys may be familiar with this Pilot.
First stop sign says, do not stop on Tracks under it. (obviously)
If you stop at 2nd Stop Sign with a 53ft trailer (48ft too probably) you will be blocking Tracks.
So.. Do I stop twice, or can I run the second Stop sign?
I did not stop twice.
Two Stop Signs and RR Crossing
Discussion in 'Trucking Industry Regulations' started by Balakov100, Aug 13, 2016.
Page 1 of 5
Legally, you would be required to stop at both. But as you see, your trailer will stretch across the tracks so i would hold at the first stop sign and when the way is clear, go, making a running stop at the second. If i remember correctly, this is a relatively unused set of tracks, but unless marked exempt, one should always expect a train.And the sight distance is such that you would probably see a train coming a ways off.
Running the stop sign is NOT a "serious offense" and will only DQ you if you've had enough points on your license to get it suspended. The RRX violation carries a 60 day DQ for the FIRST conviction.
So yeah, I'll stop at the first stop sign and wait until it is clear for me to proceed. That second stop sign will be ignored each and every time, because if I stop on the tracks and the wrong cop sees me, I'm sitting on the sidelines for 60 days. Run the stop sign and worst case scenario, it's a couple points and I keep on truckin'.
Dave_in_AZ, double yellow, brian991219 and 2 others Thank this. -
If there is a train coming soon, you stop at one.
If there is a cop coming soon, you stop at both.
Easy.OLDSKOOLERnWV, Fatboy42, TROOPER to TRUCKER and 1 other person Thank this. -
@Hick wins with the common sense answer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blackshack46 Thanks this.
Just to be clear there was no cop and I did not get ticketed or stopped even.
Was just wondering the correct way to approach this or similar situations in the future. -
Like I said, I stop before encroaching upon the tracks. When it is clear for me to proceed, I do so without stopping on the tracks. Stopping on the tracks is a pretty serious infraction...FIRST offense DQ's you for 60 days. Wrong cop sees you and writes that ticket and you're done for 2 months. Also, what if the clutch lets go sitting at that 2nd stop sign? Or you let out the clutch and break a yolk, u-joint, drive shaft, axle shaft, differential, etc...and then you're stuck there on the tracks. Shifting on the tracks is discouraged for those reasons...so why would you ever think it would be wise to STOP on the tracks?
Drive through it without stopping when you could have and get T-boned, then tell me about all the little legalities of it.
mtoo Thanks this. -
I'd personally do it Pedigree's way. I'd stop at the first stop sign and wait for traffic on the hghway to clear. The second sign gets ignored.
I run into this situation sometimes due to a rail line that runs along US-13 south of Salisbury, sometimes in fairly close proximity to the highway.
@TROOPER to TRUCKER, what's your take?double yellow and Pedigreed Bulldog Thank this.
Page 1 of 5
