I recently swapped out my halogen fog light bulbs for 50W LED bulbs. The lights turn on and work fine but the truck draws the Check light and displays a fog light low current fault in the diagnostic menu. Any way to fix this?
Volvo Fog Light LCM Codes
Discussion in 'Volvo Forum' started by AFX, Apr 17, 2016.
Reprogram the lcm is the right way unfortunately. Adding resistor will also work. Found this on another site to better explain why.
when replacing or adding LED lights the LCM sees them as an open or non existent light.
Because LED's draw less current the lcm trips a code. -
LEDs in the Fogs? SWEET !!
