I work for a material supply company and I've been tasked with looking into the feasibility of buying our own tractor trailer combination to ship our own product from MN to both ND and NE. It seems my Google abilities aren't up to snuff regarding semi trailers. When I Google "things to look out for when buying a semi trailer", the only relevant result to my unknowing eye is:
Is this pretty much the be all end all of what to look for when considering a used trailer? If not, would someone please direct me to another site or give their own input on things to look for?
Thanks for your assistance folks!
What To Look For In A Used Trailer
Discussion in 'Experienced Truckers' Advice' started by Kooter, Oct 13, 2015.
Are you looking for a dry van?
Yes. Would like our product enclosed, and does not need to be refrigerated.
You have no trucks now? Or are you adding to an existing fleet? It is far easier
and cheaper to hire a truck than it is to own one. If you already have trucks than
adding one is not a big deal. If this your first truck you might consider getting an
established company to dedicate a truck to your business. They should have
all the permits, insurances, etc required to run a truck.
If you have your own truck than leasing a trailer is definitely a good idea. They
do the maintenance, you have a fixed cost every month, etc. -
You could also get a stepdeck or flatbed with a sliding tarp system or Conestoga. These optons would give you the ability to side load your product.
It should at a minimum have tires.
Anything bent, broken or damaged. Tires should have no abnormal wear patterns. No leaks. No wiring and hose hanging down or damaged. No obvious cracks or extreme corrosion on the frame. On a van you'll want to make sure all the rivets on the exterior walls are there and not loose/falling out.
ChaoSS Thanks this. -
Hiring a truck is the best way. You also are willing to take on the added liability of running a truck? Think accident and lawsuit.
But, if you are going to do it anyhow, hire a mechanic to look it over since you do not know what to look for.
