Wheels and Tires 22.5" Vs. 24.5"
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Blackducati750, Mar 2, 2011.
  1. Blackducati750
    Blackducati750 Light Load Member
    193
    10
    Mar 11, 2009
    Bushkill,PA
    I was curious. What are the benefits of having 24.5" wheels/tires over 22.5"?
    I assume replacement 22.5" size wheels would be cheaper than 24.5" (less aluminum)
    I also assume 22.5" tires are cheaper than 24.5"...
    Is there a differnce in ride and/or handling?
    Weight?
    Or, is it just a "bragging rights" like the kids who put 22" chrome wheels on their Honda Civics?:biggrin_25518:
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,640
    Oct 11, 2010
    Borispol, Ukraine
    here we use 22.5". Truck is lower, less problems with overhight.
  4. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    All depends on what your doing with your truck. If you hual a van trl you you would probably be best suited with 22.5 low pro's or 11r22.5. If you go off road 24.5 will give you more ground also IIRC they also have a higher weight rating for over weight loads. As always it all depends on application
    Coffey and KB3MMX Thank this.
  5. 25(2)+2
    18,706
    43,386
    Sep 18, 2006
    the road less travelled
    Low pros of either height have lower rolling resistance, 11Rs can carry more weight in either height. 24.5s in low pro are about the same height as 11R 22.5. Low pro 22.5s would ride about an inch lower than low pro 24.5s to the center of the axle.
    22.5s low pros are what is specced for best mielage, but I don't think it makes that much diifference, as long as either size is low profile
  6. sixpackbill
    sixpackbill Light Load Member
    114
    29
    Oct 6, 2010
    hamilton on.
    22.5 gives lower rplling resistance,means better fuel mileage
  7. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    If you drive accordingly. If you're a hammer head tires size isn't gonna help.
    Keep in mind....
    The taller the tire the longer it will last, more it will weigh, and more it will cost.
    I've always run tall 24.5's. The ride is also better on the tall versus low pro.
    The 22.5's are good for pickups and kids toys, IMO....:biggrin_2559:
    ChadFelix Thanks this.
  8. CMTrucking
    CMTrucking Light Load Member
    85
    27
    Dec 25, 2009
    Kamloops, BC
    Tall 24.5's aren't that practical for a highway truck. Low profile 24.5's are the same size as 11R22.5's but they ride a LOT rougher. Every truck I've owned ended up having low profile 24.5's on them and if there's one thing I've learned, my next one will have 11r22.5's.
    areelius Thanks this.
  9. rjones56
    rjones56 Heavy Load Member
    823
    486
    Jul 15, 2008
    staunton va
    Taller tires = less revolutions=better fuel mileage.Thats how it works for me anyway.
  10. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,369
    14,574
    Jan 18, 2011
    Well said--among other things!
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,723
    Jan 30, 2010
    keep stroking.
    i have run 22.5 for ever last as long as 24.5s grossing 118000 and up 22.5 useally has a higher load rating than a 24.5 its what you prefer 22.5s cost less to buy than a 24.5 to.
    Hudbri11 Thanks this.
