I noticed several O/O's loading their trailer with half the load over the drives and half over the spread axles. I've belly-loaded just about every load I've hauled and just wondered what splitting the load does for you? I always thought the trailer was built to take the spring out and distribute the weight evenly. I don't think we're talking traction here because it's May and they're still doing it. What's the theory behind loading over the axles?
Why do O/O's load front and back?
Discussion in 'Flatbed Trucking Forum' started by Ken Worth, May 27, 2015.
Spread the weight out on the deck. Less stress on the frame than just putting it in the center and stressing the frame time after time.
Better rideOLDSKOOLERnWV, Ken Worth, rank and 2 others Thank this. -
more stress on the trailer if you put the load in the middle ,,maybe he unloaded some freight already or wants to leave as must room as possible to add more freight,
plus you can carry more weight on the back, and like said better ride.
Ken Worth Thanks this. -
If you have a trailer with the "coil option", its built to take all that weight in the center.
Easier to axle out if loading to max. I always loaded to save as much room as possible for lol.
Ken Worth, rank, peterbilt_2005 and 1 other person Thank this.
Ken Worth, peterbilt_2005, Hurst and 1 other person Thank this.
usually i have controll of the load and i tell them were to load it, that is the beautiful part of FB
Also its my opinion the tires on the trailer will last longer with less weight on the spread. I'd rather drag 26k lbs on the spread with 33k lbs on the drives, than the other way around,.. truck rides so much smoother.
My trailer itself will handle the weight no matter where I put it. For me its more for the ride and tire life.
HurstKen Worth and peterbilt_2005 Thank this.
