04 379 heater issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RisingBTrucking, Jan 26, 2026.
  1. RisingBTrucking
    RisingBTrucking Bobtail Member
    6
    Jan 26, 2026
    I have an 04 379 and when I start driving my heat quits blowing. The vents will still be hot but nothing comes out. When I stop it will start blowing again. When I switch to a/c it blows like normal. Blower motor is new and fuses are good. Any help would be greatly appreciated.
    blairandgretchen Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    The fuse is getting hot and tripping. When it cools it works again. Try replacing the resistor, if this doesn't work, make sure fuse is not loose in the fuse box. Make sure heater connection isn't loose, lastly could be a bad wire.
  4. RisingBTrucking
    6
    Jan 26, 2026
    Thank you, I’ll give those a try!
  5. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome! And if you have any other questions just ask, I have a 2000 379.
  6. blairandgretchen
    13,929
    76,521
    Dec 9, 2011
    South west Missouri
    Just what @bad-luck said,
    I have a 1995, not sure if your dash setup is the same, but the blower motor on mine is behind the glovebox assembly (8 screws and the whole thing is out), and I found a poor butt connector on mine causing the same issue. It's not a bad idea to check it anyway even if it's not the culprit - I found mine with clear hot/burnt spots in the connection. Clean it up and direct solder the joint.
    wore out and Oxbow Thank this.
  7. RisingBTrucking
    6
    Jan 26, 2026
    Where is the heater connection? I put a new resistor in and the fuse is tight but still the same issue.
    Diesel Dave Thanks this.
  8. Diesel Dave
    9,634
    32,529
    Jan 20, 2010
    Hesperia, Ca.
    Wonder if the spring looking thing inside the duct by the motor/blower has anything to do with it, I changed mine on my 94 when I replaced the motor, and the switch.
    BoxCarKidd Thanks this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    The spring looking thing ( resister ) should still allow it to run on high.
    Oxbow, '88K100 and Diesel Dave Thank this.
  10. RisingBTrucking
    6
    Jan 26, 2026
    I replaced it an hour ago and still have the same problem.
  11. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Check the plug where you plug the blower motor in. They are famous for getting melted and making bad connection. Might even look ok but still be bad connection. I'd do away with the plugs and hard wire
    Oxbow and wore out Thank this.
