10 to 13 speed....ECM changes???/
Discussion in 'Freightliner Forum' started by RERM, Aug 14, 2015.
  1. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    2006 Century 14L Series 60, 3.55 rear...Eaton Fuller 10spd to a 13 spd...
    1. Do I have to change/re program the ECM when doing this???
    2. Quoted $4,500 installed, good or bad? but told I'd have to change ECM????$2,500....
    3. Other changes involved?
  3. supersnackbar
    20,082
    52,466
    Aug 19, 2007
    Your Town, USA
    Unless the final ratio is different, I wouldn't know what would need upgrading on the ecm. Unless the 13 spd has a lower torque rating and they want to turn down the torque...but I doubt that is the case.
    Depending on the length of the 13, you may need a shorter drive shaft between the transmission and the center support bearing.
  4. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    Have a friend who changed from a 10 to 13, I figured he would have to change ECM.He is using it everyday,just had it re-programmed. Cat-a- puller engine.
  5. supersnackbar
    20,082
    52,466
    Aug 19, 2007
    Your Town, USA
    On a Series 60, I don't think the engine even communicates with the transmission other than the speedo/output shaft sensor.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    The ECM has parameters for rear axle ratio and top gear ratio. If you replace a direct drive trans with an overdrive, you'll need to change the top gear ratio. This is not a big deal and does not require the ECM to be replaced, just a 5 min parameter change (plan on paying the 1 hour min labor at a dealer though).
    What happens if you don't change it? I'm not really sure. I know it uses that info with engine rpm to know when you're in top gear and top gear -1. There's a few things that might/could be affected. I'd just change the parameter and know it right.
  7. jim3029
    jim3029 Bobtail Member
    38
    11
    May 27, 2012
    Janesville,WI
    I had mine changed from 10 to a 13 and I asked them the same question and they said no changes were needed. I have the 12.7 Detroit 60 series ddec 4. I have had no problems and it's been almost 1 1/2 yrs.
  8. Archie bonker
    Archie bonker Bobtail Member
  9. Archie bonker
    Man I want to do what you have done can I get the details
