14l no power
Discussion in 'Freightliner Forum' started by 06freightshacker, Mar 29, 2023.
  1. 06freightshacker
    06freightshacker Bobtail Member
    Hello all have a 06 columbia with a 14l it says 515 hp but dosent feel like it and when it spools up there is an other whistle like the turbo but sounds like the drivers side any help would be greatful
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Sounds like a boost leak get out and look once.
  4. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    I second the Motion Likly boot with a hole or loose clamp or something
  5. 06freightshacker
    I've changed all the belows intake tube new boost actuator search all over
  6. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    Have you Checked the Intake Manifold Gasket and also the EGR crossover pipe and the V/Band Clamp where the Intak manifold and the short pipe meet where egr crossover pipe comes together
  7. blairandgretchen
    13,929
    76,539
    Dec 9, 2011
    South west Missouri
    CAC pressure test to isolate at standing.
    Often those fresh clamps will need re-torqued after running a few miles, mine - last changed, needed nipping down twice, it had a real high pitch fart sound under boost.
    Oxbow Thanks this.
