4" 30' Straps
Discussion in 'Flatbed Trucking Forum' started by scottied67, Apr 18, 2020.
  1. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    What is your favorite way to keep 4 inch 30 foot straps rolled tight and stowed away in the box so they won't fluff out.
  3. JonJon78
    JonJon78 Road Train Member
    7,238
    42,995
    Jul 1, 2018
    I keep 12 of them rolled up in a milk crate stowed in one of my trailer boxes.They stay nice and snug.
    alds, scottied67 and Klleetrucking Thank this.
  4. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    Personally, I like to roll them free end first so the hook is "out", then hang the hook on the rubrail and take the roll between my palms and get them really tight. Kinda hard to explain. One plus for me rolling them this way is you're throwing the strap and not the hook as well.
    I do assume we're talking about straps with a flat hook.
    scottied67 and Lostkeys Thank this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Try those big rubber bands they sell at truck stops. I use a strap winder and get them tight, then back off half a turn, rubber band and tuck them away.
  6. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Cut up an old inner tube for rubber bands. Lawn mower front tire is about the right size.
    scottied67 Thanks this.
  7. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    I use the rubber bands most of the time. But like @FoolsErrand said, an old inner tube works just as well.
    @Klleetrucking, I roll my straps just like you do. I roll starting at the free end and hang it on the rub rail and pull really tight to condense the strap as small as possible
  8. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    I use old motorcycle Heavy Duty tubes hold up good
  9. D.Tibbitt
    156,704
    I roll em up , but dont get em tight , i do it the quick way and can out perform most strap winders . I seen guys use rubber bands, to much work and more equipment to keep track of.. Get some pieces of wood and block off a section of storage box and put starps in that one section . Roll em up hook out and place strap sitting up right with hook flat onbottom of box. Keeps them from unraviling. Put them side by side and stack high. I put extra ones that have banding , at the front of the box and it keeps all the rest in check and keep them from unraviling. The only problem is most flatbedders got so much frickin equipment , no matter how much storage u have its never enough and it gets cluttered real quick
  10. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    You running open deck now?
    I used to put them in my box side ways, eye to the side so to speak, and just put them next to each other so they didn't have room to unroll. Three to a row, do a few rows and start stacking them in pyramid formation. Tended to keep them together just fine.
  11. scottied67
    10,826
    12,675
    Mar 14, 2010
    california norte
    Yes. It is pretty cut and dry. Roofing tiles one way and treated utility poles going the other way. Same kind of loads all the time so no fancy securement knowledge needed as when you haul all kinds of different open deck freight each load. So far so good....
    baha and Speed_Drums Thank this.
