AC not cold anymore
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 26, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    This trip I've had AC not blow as cold as it used to. It would literally be freezing cold in cab and I'd even turn it down from 4to 3rd setting.
    Now on full blast it's barely cool and idk what it could be? Stuck expansion valve?
    Trucker61016 and Walk Among Us Thank this.
  3. JB7
    JB7 Road Train Member
    1,008
    1,781
    Dec 13, 2022
    Laurel, MD
    With the truck running and a/c on check to see if the clutch on the front of the a/c compressor is turning. If so, then you likely have a leak and need to connect a set of gauges to read the pressures. If the clutch is not turning then the system is low or out of refrigerant or there is an electrical problem.
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    Oh the compressor works fine, clutch engaged and blowing cold but not as cold as it used to
  5. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    Just add some freon
  6. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Most common cause is low freon.
  7. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    The AC works on btu exchange. If you have bugs and other road debris in front, stuck to the condenser, you can not get rid of the heat, thus can not make things cold.
    Wash the condenser out good with water, then see if that makes it cold.
    If somewhat better, but still not what it used to be, your cabin filter could be clogged, and/or compromised allowing dust and other junk to accumulate on the evaporator, again, not allowing the fan to remove the cold from it before returning to the cycle.
    Vampire Thanks this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
