Air Condition Question
Discussion in 'Freightliner Forum' started by Bob.g, Mar 26, 2016.
  1. Bob.g
    Bob.g Light Load Member
    74
    23
    Sep 28, 2015
    Is the air compressor supposed to work continuously when the temperature outside is cold such as 30 40 degrees?
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    are you running defrost?
    Bob.g Thanks this.
  4. Dna Mach
    Dna Mach Road Train Member
    3,301
    3,145
    Aug 8, 2008
    Texas
    No it isn't. Defiantly want to get it looked at ASAP as it's more than likely something very simple and much less expensive than the compressor itself.
    Check your sleeper controls. In some trucks when the AC switched is on back there it will over ride the dash setting.
    Bob.g Thanks this.
  5. Bob.g
    74
    23
    Sep 28, 2015
    OK mine doesnt run all the time i thought it might need to it turns off and on a lot and i thought that maybe there is something wrong with it
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Thats different it turning off an back on at short bursts can be a sign of low freon, the low pressure switch should cut comp. all the way off when it gets to a preset low freon pressure?
    Bob.g Thanks this.
  7. Bob.g
    74
    23
    Sep 28, 2015
    My freon is good it might be the pressure switch im not too sure what it could be
  8. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Is your air conditioning working ( keeping it cool ) if so there is nothing to worry about the compressor doesn't run all the time it will cut in and out as needed to keep the freon compressed
    Bob.g and AModelCat Thank this.
  9. Bob.g
    74
    23
    Sep 28, 2015
    That what im assuming, could the weather be in effect this?
