Air leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Jul 25, 2019.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    97 freightliner fld secondary gauge losing air 120 lbs to 5 lbs in 15 min. Where to start looking for leak. I have 4 air tanks.
  3. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Might be a able to hear the leak. Take it to a quiet area and closely listen in all the areas.
    heavyhaulerss Thanks this.
  4. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Does it lose air without the brakes applied?
  5. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Set trailer brake, choke wheels and release tractor parking brake. Get out of the truck and listen for air leaks
  6. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Agree with others. That much loss should be very audible.
  7. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Does it happen with valves out? If so, this will narrow down the possibilities. If not, try it with one valve in at a time and try to isolate the leak.
    Example. Trailer or truck. Emergency pressure or brake application pressure.
    This can all be done right from the cab.
  8. brysol01
    brysol01 Medium Load Member
    319
    456
    Nov 2, 2009
    don"t forget the spray bottle of soapy water, my first truck was a 97 FLD 4 axel
    to run paper from Ponderay to Salt Lake, great truck till Freedom Freightliner in
    Spokane rebuilt the engine
  9. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    Do you have a dump valve? Dump your bags and see what happens. If no change at least you eliminated one part of the system.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Thank you. all. I found it. It is some sort of pressure relief valve on the short air tank. Looks like a button on 1 side and it was pouring air. freightliner had it in stock. Much appreciate the help.
    uncleal13, 062 and RustyBolt Thank this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    A59ED954-0014-434C-9E22-F38BBE62D10F.png I use one of these Ultrasonic Leak Detector. It’s the cats meow.
    I’ve found leaks I didn’t even know I had. My truck use to go 20 minutes between compressor purges. Now I goes two hours and I pull two trailers.
    heavyhaulerss and Hegemeister Thank this.
