Air Leak
Discussion in 'Ask An Owner Operator' started by Hayfieldmn, Apr 6, 2022.
  1. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    been looking for a air leak for a month now, compressor runs about every 10 min driving down the road, ive sprayed every hose and fitting and nothing!! its a 2018 389. front air ride. my front will drop over night, and both tanks will be at around 50psi, without a trailer on either so it has to be the truck. Any input would be greatly appreciated!! Thanks!!!!!
    D.Tibbitt and Rugerfan Thank this.
  3. Dale thompson
    5,437
    46,975
    Nov 20, 2013
    commerce twp,mi
  4. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Once all your bags are inflated, jack the truck up to extend the bags, and spray them down. Could be leaking between the bag and the base.
  5. AModelCat
    164,195
    Check fan clutch. Engine off, key on you might be able to hear it. Some engines apparently use air for the turbo actuator as well.
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I would say the compressor is having trouble keeping up with the leak in the steer axle suspension. There’s a leak there somewhere if it drops overnight. On the road the compressor has to keep up with the leak as well as whatever the ride height adjuster calls for on the road. God prefers Diesels sent you on the right trail. You already know which axle needs checking.
  7. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    If bags are deflated it's a giveaway that one or more of air bags are leaking. Check air dryer as well as mentioned above
    Hayfieldmn and Dale thompson Thank this.
  8. 86scotty
    86scotty Road Train Member
    4,688
    12,867
    Aug 27, 2017
    Appalachia
    Compressor runs about every ten minutes while running down the road? Sounds completely normal to me. I don't worry about slow leaks overnight. They come and go. I don't spend time chasing them down if I can't hear them audibly walking around the truck.
  9. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I’m exactly opposite. I’m the loon you see under his truck with a spray bottle of soapy water and a handful of wrenches. I can park overnight with a loaded b-train and if it’s not windy enough to bounce the truck around a lot my low air alarm doesn’t come on when I start the truck in the morning.
  10. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    You need an ultrasonic leak detector.
    I just bought one.
    I'm going to make my truck so that I can shut it down and go on vacation and when I come back my tanks will still be full, lol.
    I have not tried it yet but I will over the weekend. I'm curious to see how it works and what I find.
  11. Hayfieldmn
    158
    239
    Sep 10, 2016
    Back to the shop for some more checking, Thanks everyone, I did just find a leaking brake chamber, gonna replace that tomorrow, but it still don't solve the front air ride dropping over night.
    Dale thompson Thanks this.
