Another cruise control/high idle issue.
Discussion in 'Peterbilt Forum' started by HillbillyDeluxeTruck, Oct 29, 2020.
  1. HillbillyDeluxeTruck
    5,952
    30,449
    Mar 3, 2013
    San Antone
    Ive been chasing this for a week. Cruise/high idle would work, then wouldn't. Engine brake always works. I have read, diagnosed, read more and found nothing that could cause this.
    Finally just 10min ago I fired the truck up to get some heat in the cab, and I try my high idle. It works. Since its dark, I flipped my marker lights on and the high idle kicked off. Marker lights off, it works again. Flip on headlights, high idle kicks off. So I have successfully figured out the issue, now I need figure out WHY its doing this. How would the lights equate to interrupting the cc/high idle function?
    Truck is an 02 379 with a C15, btw.
    blairandgretchen Thanks this.
  3. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    ...i had same issue but when driving on cruise and turn right signal - cruise shuts off , it was shortage ...dont remember what kind , mechanic figured out fast ...same at idle , turn right signal - shuts right off
    650cat425 and blairandgretchen Thank this.
  4. blairandgretchen
    13,930
    76,550
    Dec 9, 2011
    South west Missouri
    Went round and round with mine too.
    My guess -
    The series of switch positions that have to be correct run through a common wire - like ‘543’ - someone has tapped into that wire and used it as a ground for the markers.
    Peel open that ‘C’ panel and trace the marker light wires.
    650cat425 Thanks this.
  5. HillbillyDeluxeTruck
    5,952
    30,449
    Mar 3, 2013
    San Antone
    Man, youre like my Dalai Llama :D
    Noticed last night that when I step on the brakes, the side marker lights that someone installed, turn off. Let off the brake, they come back on.
  6. blairandgretchen
    13,930
    76,550
    Dec 9, 2011
    South west Missouri
    Well - what did you find so far?
  7. HillbillyDeluxeTruck
    5,952
    30,449
    Mar 3, 2013
    San Antone
    I completely forgot to update this. I figured out that my high idle will work when all my lights are off. If I flip on my marker lights or my headlight, it disables my high idle/cruise. I believe the issue is related to some lights that have been mounted under the sleeper. I noticed that they blink opposite of my turn signals and actually go off when I step on the brakes. I still need to trace the wires and see how they're wired in.
