Any idea what this is?
Discussion in 'Refrigerated Trucking Forum' started by 88 Alpha, Jul 27, 2016.
  1. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    My boss wanted me to hook to a reefer trailer for a few days. I've pulled them before but that was at least 15 years ago. Man, things sure have changed.
    The trailer he wanted me to pull has the keypad-thing you see in the accompanying photo. At first, I thought it was a keypad lock for the vent/pulp door on the rear but when I opened the right trailer door, I realized the trailer doesn't have a vent door on it. I don't have a clue what that keypad is for.
    Also, this trailer has what appears to be 3 or 4 recessed lights in the roof (8"-12" long LEDs). The fixture has what appears to be a gray button in the center of each rectangular fixture but using my broom to push the button has no effect.
    Any reefer-haulers have any idea about either one or both of the items?
  3. HughJack
    HughJack Light Load Member
    77
    53
    Sep 14, 2012
    looks like it should control some kind of bolt / locking device inside the door. Never seen one of those either!
    88 Alpha Thanks this.
  4. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    It's a keypad for something
    ZhenyaP1991, yuban, x1Heavy and 5 others Thank this.
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    I concur.
    x1Heavy, 6daysontheroad and tucker Thank this.
  6. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    I deserved that. Might should have titled the thread a little differently.
    x1Heavy and tucker Thank this.
  7. pookie-wookie
    pookie-wookie Bobtail Member
    Jul 27, 2016
    that looks like an electronic keypad for an intrenal lock for the rear door...(?).
    x1Heavy and 88 Alpha Thank this.
  8. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    That sounds like it is similar to an electronic lock on a gun safe. If that is the case, apparently it has been disabled. When I picked up the empty trailer, I was able to open both rear doors simply by pulling up on the (4) door-latches like you normally would. No bells, whistles, sirens, or alarms went off when I opened the doors.
    Also, I was under the impression the trap door/vent door on the right rear door was a standard feature on reefer trailers. Since this one doesn't have one, does that mean those little doors have become an optional item?
    x1Heavy Thanks this.
  9. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Start punching in random sequences of numbers, see what happens....
    firemedic2816 and tucker Thank this.
  10. dngrous_dime
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    And yes, the vent doors seem to be optional. I'd guess that fewer than 20% of our trailers have them. Really annoying, because I sometimes pick up preloaded sealed trailers, and I have no way to see how it's loaded.
  11. 88 Alpha
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    After I got empty this morning, I did that very thing. I entered some codes that are common with keypad devices. You could hear an electronic tick when I pressed the digits, but that's all there was, just ticks corresponding to keypad entries. Nothing else happened.
