Anybody see a problem here?
Discussion in 'Heavy Haul Trucking Forum' started by Oxbow, May 3, 2018.
  1. Oxbow
    Oxbow Road Train Member
    13,608
    140,965
    Nov 24, 2015
    Watch at 20:30:
    I am not posting this to pick on the guy, but rather to help educate those that are learning like myself.
  3. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    I'm impressed he used edge protectors under the straps on the boom.
  4. Landincoldfire
    Landincoldfire Heavy Load Member
    914
    5,023
    Sep 27, 2015
    New Holland, Pa
    I see he got a new truck.
  5. Oxbow
    13,608
    140,965
    Nov 24, 2015
    If I owned the hoe I would request that the stick ram be removed and check for straightness. Putting the weight of the boom on the side of that ram is a bad move in my opinion.
  6. blairandgretchen
    13,870
    76,048
    Dec 9, 2011
    South west Missouri
    Way out of my league right now. I'll need a quick explanation.
    austinmike, MACK E-6 and Feedman Thank this.
  7. Oxbow
    13,608
    140,965
    Nov 24, 2015
    The weight of the boom, stick, and bucket, which I would guess adds up to 30,000 lbs. or more, are all resting on the side of the stick hydraulic ram, plus whatever down pressure is being applied by the straps. That ram is not designed to be loaded against it's side. Damage can occur by bending the ram. Even if the ram flexes enough but doesn't bend, side pressure is applied to the seals which could damage them and cause leaking.
    @johndeere4020 , and @truckdad ,you guys haul excavators all the time. What are your thoughts?
  8. John3009
    John3009 Bobtail Member
    39
    26
    Aug 4, 2016
    I’m not a big fan of how he’s got a side pull on the d rings at the front of his trailer on top of the rail.
  9. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    I’ve had to do it in the past, I carry small pieces of plywood and other blocks. I usually uncurl the bucket which will move the cylinder away and stick some wood between the cylinder and the stick then curl it back up. That makes everything solid, it’s not ideal but sometimes it’s your only choice.
    I’m not sure where he’s running so I’m not sure his max permissible weights but I would have slide the fifth wheel forward and backed the machine toward the neck more. That would have dropped the dogbone down on the rear cross member and probably cleared the cylinder and dropped the height.
    SAR, MACK E-6, truckdad and 2 others Thank this.
  10. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    I do all the time never had a problem.
    SAR Thanks this.
  11. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    the only "problem" i see is, is that dude got's one HUGE snozzola...and he's gonna get skin cancer it being so far out and in the sun.....
    Bakerman Thanks this.
