Anyone know what part this is
Discussion in 'Freightliner Forum' started by 4noReason, Nov 18, 2016.
  1. 4noReason
    4noReason Road Train Member
    2,392
    752
    Nov 29, 2012
    I think its turbo but not 100%. Its oil leak but small and it burnt into this when it gets hot. I have warranty so id like to know what it is 2012 cascadia
  3. 4noReason
    2,392
    752
    Nov 29, 2012
    Its a 2012 cascadia btw
  4. ytruck
    ytruck Bobtail Member
    Nov 18, 2016
    Tengo Un cascadia 2011 Que CUANDO ESTA Cargado y aprieto el Pesar Hace La Mismo ruido que hace? Cuanto se q hacerese ruido
    4noReason Thanks this.
  5. supersnackbar
    20,085
    52,483
    Aug 19, 2007
    Your Town, USA
    Looks like the plumbing for the EGR valve. Turbo's are big, and are in front of the bottom end of that pipe.
  6. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Follow the stains up, that photo is not the bad part. You need to find where that coolant is coming from. Egr cooler would be my guess.
    4noReason and magoo68 Thank this.
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    ^^^^^^^^What he said. EGR cooler.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    men I don't understand what you want to know. it's coolant leak. use your eyes and find out from where it is coming out. find the place of leak and post the photo. this photo just shows coolant dried everywhere not the leak area.
  9. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Probably coming out of cab heater hoses which are located right on top of where you took that picture probably a broken hose or a loose clamp egr cooler never usually leaks outside check higher up from where u took that picture from. you will be able to find your leak i doubt warranty is going to cover it but it's a relatively cheap repair.
  10. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    the hose on def heater line.. its just above of egr cooler...
  11. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    Don't really know what your asking. That's not an oil leak though. It's coolant should be easy to track it down.
