APU Heater
Discussion in 'Questions From New Drivers' started by Storm2020, Nov 12, 2023.
  1. Storm2020
    Storm2020 Bobtail Member
    Georgia
    My APU has been working great until tonight. It's 32 currently ( been in cold weather last few weeks with no issues) now it's blowing either freezing cold air and will alternate warm air as long as it is turned all the way up but won't get hot. I live in South so this is just to cold. Any ideas what it cold be before calling shop.
  3. Lockport
    Lockport Light Load Member
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    Sounds like the heater itself. Typically they have two stages of heat. Just guessing but it may be hitting only the low stage and then its trying to go into the second but not hitting anything. They're easily replaced and if memory serves correct, but that expensive. Most trucks with shore power will only use the first stage, just designed to keep things from freezing. Maybe 45° when it's 10° outside.
  4. roshea
    roshea Road Train Member
    What APU do you have ?
  5. Dna Mach
    Dna Mach Road Train Member
    3,301
    3,146
    Aug 8, 2008
    Texas
    Do you have an Espar bunk heater? It will be a small black box under the bunk with a duct in and duct out….
  6. roshea
    Espar requires a little bit of maintenance to keep going. They usually get ignored until not working properly.
  7. Lockport
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    The larger Espars typically do not seem to require maintenance in my experience. I know the smaller ones constantly clog the little screens. One trick is to prime it with kerosene which will burn hotter and burn off the gunk but the heat has a tendency to weld the screen to the casing and then replacing it, which you'll eventually need to do, is very difficult.
    Then there's the $100 Chinese heater option, but I've heard horrible things. There is a unit called the Parking Heater Pro (PHP). They are made in China but to strict specifications and they are about half the price of an Espar. I have the large going into 3 winters now.
  8. roshea
    running clear unscented K-1 kerosene through your espar for about 45 minutes is the accepted way to get carbon deposits burned out, do it once a year. I've never had the screen clog up, I usually replace the screen and glow plug every 3-4 year. Remember to run it once a month even during the heat of summer to keep it in good working order. Doesn't take much to keep them going.
  9. Lockport
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    I had one of the smaller Espar brands once and it used to clog up and error about every other month. I had another 4kw Espar, the big one for 4 to 5 yrs and never had to do anything to it. And, yes, fire it a couple times in the off season.
