Apu is overheating
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dragonmywagon, Jul 24, 2016.
  1. Dragonmywagon
    Dragonmywagon Bobtail Member
    5
    Jul 18, 2016
    My apu will run about 30 minutes then shut down. The temp light is on on the panel. So I figured the fan was bad. After changing that it still does the same thing . All fluids are full. I have a carrier comfort pro. I am guessing it would be the temp sensor. Where is it at on this apu?
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    OK, this is an admittedly half arse guess, but is there an intake air filter that could be plugged?
    Dragonmywagon Thanks this.
  4. Dragonmywagon
    5
    Jul 18, 2016
    Air filter was dirty. So changed it but still shut down within 15 minutes. Pretty sure it is the temp sensor
    Reason for edit: Changed answer
    Big Don Thanks this.
  5. Kamkor
    Kamkor Road Train Member
    3,324
    3,570
    Jan 18, 2012
    Wellington, TX
  6. Kamkor
    3,324
    3,570
    Jan 18, 2012
    Wellington, TX
    magoo68, albert l and Dragonmywagon Thank this.
  7. WheresWaldo
    WheresWaldo Light Load Member
    109
    64
    Nov 23, 2016
    Oklahoma
    Check your 15A fuse. Proper coolant purge. ALT/Water pump belt proper tension. Then go with seeing if the radiator fan is working. Kicks on at 170. 15 amp/ bad fan switch, or faulty fan. proper function of the thermostat. If still mystery and everything is working change over heat temp sensor. Still on curring issue it needs a head replacement.
    Comfort pro specialist at your service.
    PE_T, Rackpass 85 and driverdriver Thank this.
  8. Wally2013
    Wally2013 Bobtail Member
  9. Wally2013
    Hey, how did you end up fixing the problem ? My unit shuts down too just like yours. Took it to Philadelphia Carrier dealer 3 times. Paid 3 times with no success. I had another Carrier dealer in Texas say the problem was an oil temp sensor, Philly said no it wasn't and didn't replace the sensor even when I asked them to... Looking for a resolution.... G
  10. WheresWaldo
    109
    64
    Nov 23, 2016
    Oklahoma
    Overheating issues. Is your fan kicking on? No, check the 15 amp fuse. Fuse is fine? Might be your fan switch (sensor behind the unit down on the backside of the radiator.)
    Fan is running could be a bad overheat sensor that kills the unit randomly. This sensor has been known to be replaced because it has a I wanna say a 5lb torque limit, and tends to be over torqued causing the probe inside to break.
    If you have a reservoir on the back of your truck for your unit, length of hoses can be a factor, also they're is a burping/ purge procedure that is fairly easy to do when topping off your coolant reservoir. Also when doing this procedure I usually tighten the alternator/ water pump belt. I I should of listed this procedure first cause this is my first steps when dealing with over heat issues.
    Could possibly be a stuck thermostat.
    Your unit should be serviced every thousand hours. Cleaned/ washed from road grime. Air filter changed.
    Sorry how unorganized this post was. Did it on my phone.
    PE_T Thanks this.
  11. WheresWaldo
    109
    64
    Nov 23, 2016
    Oklahoma
    Dang saw that I answered that almost a year ago. Anyways sorry you're having to deal with people who just take guesses and yet you still have to pay that labor rate.
