Auxiliary Clunks When Splitting Gear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Koba Gold, Aug 14, 2020.
  1. Koba Gold
    Koba Gold Bobtail Member
    British Columbia
    Hey guys,
    New to the forum and fairly new to the trucking biz.
    Sometimes when splitting a gear from low to high I get a clunking sound, like as if there is slack in there or something.
    Happens when loaded or empty.
    I'll be driving, foot on throttle, flip from low to high, left off the throttle and CLUNK!
    Any insight would be greatly appreciated.
    Transmission is an 18 speed Eaton Fuller on a Tandem 1998 kenworth with an N14 4:30 diffs. Also just had the front diff replaced.
  3. bad-luck
    bad-luck Road Train Member
    3,426
    6,310
    Nov 16, 2013
    Baltimore, Maryland
    Could be u joints and or a bad yolk. If it is coming from the transmission could be the synchronizer is going bad
  4. AModelCat
    164,278
    Split or range? Split has no synchronizer IIRC.
    If its the split, may want to check the regulator on the transmission. The transmissions are designed to work at something like 70 or 75 PSI. Not sure of the exact spec but if the piston is getting full 120 PSI I believe it can cause harsh engagement during the low to high split.
    Oxbow, Deere hunter and 650cat425 Thank this.
  5. Koba Gold
    British Columbia
    It's the splitter, grey thumb switch on the side, and I have it narrowed down to gears 5 and 6. When splitting from low to high in either of those gears it's sometimes clunks. I can split every other Gear with no issue
  6. Loneone-
    Loneone- Bobtail Member
    Ever figure out what the problem was?
  7. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    I would hope so since it was 3 years ago.
  8. Ericgzz711
    Ericgzz711 Bobtail Member
    did you solve this issue if so what was the problem? I’m having the exact same symptoms
  9. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    That was his one and only post from 2020 and he's never been back.
  10. Judge
    91,632
    syncronizer is out, also called slave gear, plus change the splitter button itself.
    It’s not that expensive, shops will fix it.
    Deere hunter Thanks this.
