Axle bounce
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KittyKicker, Apr 21, 2019.
  1. KittyKicker
    KittyKicker Light Load Member
    196
    100
    Dec 27, 2015
    I have 2 386 Peterbilts that both have developed a sort of hop at speed. I notice it when I drove one the other day. At first I thought it was the spring ride trailer I was pulling. After a while I realized it was the truck and it only seems to do it when I'm going about 60 to 65 and when there is little to no tension on the driveline. If it starts bouncing and I let out of the throttle completely or hammer down, it stops. It feels almost like a hub pilot is worn but it doesn't do it all the time. I said something to the driver of my other 386 and he said his does the same thing. They both have Flex Air suspensions. Motor mounts? Suspension bushings?
  3. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Grease you're 5th wheel.
    KittyKicker Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Time for new shocks?
    I had that problem with the w9 I drive. Still waiting for the steer shocks and trailer looks like it needs too. But I'll probably be dead before that ever happens.
    The 4 drives helped though.
  5. KittyKicker
    196
    100
    Dec 27, 2015
    It's greased up and slick as can be.
  6. KittyKicker
    196
    100
    Dec 27, 2015
    I forgot to mention that in a tight turn (like turning around in a parking lot or leaving a truckstop) you can feel a shudder as well.
  7. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Driveshaft needs balanced is my guess
  8. KittyKicker
    196
    100
    Dec 27, 2015
    No, the vibration is too slow to be the driveshaft. It's more of a bounce, as if driving on egg shaped wheels all of a sudden.
  9. Epicdudejo
    Epicdudejo Bobtail Member
    42
    13
    Mar 7, 2019
    At the risk of sounding too simple...are the tires properly balanced?
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Still could be the driveshaft.
    When you grease it,does grease come out all 8 caps(4 on each u joint)?
  11. KittyKicker
    196
    100
    Dec 27, 2015
    Yes sir.
