Axle temp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Miro1988, Jun 2, 2024.
  1. Miro1988
    Miro1988 Bobtail Member
    6
    May 26, 2024
    Hello, just measured with heat gun, front drive axle is hotter on passenger side, and rear drive axle is hotter driver side
    same temperatures, high 140 low 120
    Axle is around 200 front 190 rear
    This difference is normal?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    You are not over 250 degrees? Twin sticks to the dash!!!
  4. Miro1988
    6
    May 26, 2024
    No, it shows 200 front 190 rear
    checked with gun, same
    just hub temps are different
    But not on one side , diagonal
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I appreciate your diligence but maybe you are over thanking things a bit?
    Was taught to touch the tires and the hubs when you came in off the road. If you smell a burning rubber smell you probably have a tire going bad. A tire low on air pressure will be hot. If you are really concerned about steel spit on it. If it boils you have a problem. Heat guns a good tool. Good day Sir.
  6. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    I believe temp differences in hubs would because of which wheel bearing more of the load-being turned. Not all wheels are being turned at same time.
  7. blairandgretchen
    13,926
    76,502
    Dec 9, 2011
    South west Missouri
    Yes - RF wheel end will be higher, front axle higher than rear.
    I went through this about 8 years ago with a temp gun, and a more experienced driver explained it to me.
    I put the temp gun away after that and devoted my over analyzing to envisioning whirled peas.
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I question that somewhat but will not say it is incorrect.
    Do know that a bearing adjusted on the tight side will run a little hotter.
    Rideandrepair and MAMservices Thank this.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Bear in mind there is a large difference side to side depending on sun side vs shade side, can be as high as 40 degrees on its own
    A 10 degree diff side to side on same hub isnt anything to worry about, like boxcarr said, if it sizzles, thats no good
  10. AModelCat
    164,482
    Front drive has many more moving parts. That's where the main discrepancy in temps between front and rear come from.
    As for left and right varience the only thing I can think of (besides wheel bearing adjustment) is the position of the carrier in the housing.
  11. SmallPackage
    5,777
    18,536
    Dec 20, 2019
    Marion Texas
    Shorter axle in a diff may run hotter due to less mass to dissipate heat. Most twin screws without interaxle power divider locked in power the right side axle in the front diff and left side in the rear diff. 9 times out of 10 when an axle twists off and snaps it is either right front or left rear.
    Rideandrepair Thanks this.
