Backing into tiny spots
Discussion in 'Questions From New Drivers' started by TravR1, Sep 4, 2021.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,759
    Nov 9, 2017
    TX
    I asked this over in the crete section, but figured it's good to ask here too.
    I had to drop a trailer at a Walmart DC and the hole was very small. So narrow I could barely fit between the trailers, and I'm skinny.
    Looking at the hole, I knew it would fit, but not by much. So I set up and did it.
    First GOAL, everything looked good. Backed about 5-10 feet. GOAL again, and I was only 1 inch from trailer on my right side. It was very close. On my sight side it was looking like it would go in. But it was very close there too. It was making me uneasy.
    So I wiggled it a bit, not enough, it seemed.
    Luckily a yard dog came and grabbed that trailer on my right and took it. So after that, easy. The yard dogs were whipping those trailers in like it's nothing
    So how do you handle those tiny holes? Is there a different setup you use? It was 90 degrees backing up and I was using just the standard setup maneuver.
    Would it be better to not pull as far away from the hole when setting up and swing harder? It would get my tractor very close to trailers on the other side.
    My backing is so-so. It works for docks, and most situations. But apparently not the Walmart yard.
  3. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    You got it in. So your skill is good.
    Your procedure sounds good. Back some. Look. Adjust if needed, back some more.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Yard dog guys at big dcs move hundreds of trailers a day, dont worry about them, x2 what xsetra said
  5. Redtwin
    Redtwin Road Train Member
    5,515
    7,686
    Aug 17, 2012
    PBC, FL
    Best advice I can give for those packed in trailers is to back it in almost all the way in, then crank landing gear down to with an inch or two off the ground and then back in fully.
    I was half way to a heart attack, on my knees under a trailer trying to crank down landing gear when I saw another driver do exactly when I described above.
    Yes, I felt stupid, but hopefully that driver didn't spot me on my knees doing the deed.
  6. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    I actually had that thought. I thought I am going to have to crawl under. Then I thought if someone just drove by and knicked the trailer while I was inbetween them, or if there was an earthquake or something that shook those trailers even just a small amount, I would be crushed.
  7. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    I wasn't getting it. The yard dog took trailer in my right, so it was easy after that.
    But I came to 1 inch of that trailer. The second GOAL saved me.
    I was pulling up, trying to adjust, wiggle it. But it wasn't quite going.
  8. Redtwin
    5,515
    7,686
    Aug 17, 2012
    PBC, FL
    Umm when it comes to trailers in drop yards, the correct response is always..."Those scratches were already there". Always.
  9. Judge
    91,333
  10. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    Was that driver having a stroke or something? That's really bad. LOL
  11. Dave_in_AZ
    421,553
    Just like you did it. Goal 10 times if you need to. The more you back the better the difficult ones become.
    And don't be afraid to go and find a yard dog and tell him it just ain't possible.
    Those yard dogs ding up a lot of trailers too.
    Look up my thread called "BLIND." LOL. That was during my local adventures.
