Bad start
Discussion in 'Ask An Owner Operator' started by Heavenbondtransportation, May 30, 2019.
Bad start
  1. Open
    0 vote(s)
    0.0%
  2. Now
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Heavenbondtransportation
    Heavenbondtransportation Bobtail Member
    Can someone help me with this I have a 2016 freightliner dd15 Cascadia with 45000 miles on it and every once in awhile all of a sudden if I cut my truck off it won't turn back over, 3 to 4 times this happen to to now, I have to get a push to clutch start it by pop clutching it. I took it to the freightliner but they can't tell me what's going on until it's happening has anyone had this problem what their truck?
  3. Heavenbondtransportation
  4. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    When you try to start truck is there any noise, when keying to start?
  5. Tb0n3
    Tb0n3 Road Train Member
    4,722
    9,609
    Oct 5, 2012
    Earth
    Bad starter? Have you hit it with a hammer?
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Will it crank or what exactly does it do?
  7. roadranger550
    roadranger550 Light Load Member
    143
    131
    Jun 20, 2016
    You mean the starter wont work, or it turns over but engine wont start?
  8. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    I have a 2016 Freightliner with a Detroit Diesel, and had the same problem when it was still a company truck. My issue was resolved by a starter replacement.
    When the truck fails to start, do you hear any tones or beeps that are not normal?
    My truck always gives a steady tone for a while, then the OnGuard system beeps once when it is finished calibrating. Then I crank it, and there are no more electronic noises.
    When my starter failed, and when my batteries were bad, there was an additional beeping while turning the ignition.
  9. Dave_in_AZ
    421,169
    1) Check your battery connections and connections to starter. They all go on one big bolt, and it can come loose.
    2) Could be the clutch / starter safety interlock. SLAM your clutch pedal all the way down several times, see if it starts. This can be defeated by taking like a #8 or #6 gauge wire and touching it from the positive lead ( red ) on your alternator to the large bolt I mentioned on the starter.
    3) If bypassing the clutch safety switch doesn't work, you probably need a starter.
    Just replaced one in Truck 2 just like yours, similar mileage.
    Farmerbob1 and JoeyJunk Thank this.
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    My international did this right from the git go, It might do it and then not do it again for 5 months to a year. I could jump across the solenoid just enough to make a sound, then hit the start button and it would start.
    After 4 or 5 years I finally went ahead and changed the starter and cured it. I could have just changed tthe solenoid I am sure.
  11. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    that clutch safety switch be my guess, idk why they even put em on crapcadias
