Blower switch pigtail
Discussion in 'Peterbilt Forum' started by manleyman, Dec 11, 2020.
  1. manleyman
    manleyman Bobtail Member
    15
    15
    Oct 4, 2020
    I'm trying to find a part # for a replacement pigtail to fit 1990 379 fan blower switch. The Paccar # for the switch is 322005BSM.
    I've got two 90 models and both connectors have melted in the past. Seems to be a common problem with these models.
    blairandgretchen Thanks this.
  3. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    It's a Packard 56 series connector, now Delphi...wait. Aptiv, it's Aptiv now
    The Delphi/Aptiv part number for the housing is 12004327
    https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/12004327?qs=IZo/4GmaPbQcM/ZTPz6Z3g==
    You have to order the terminals separately If yours can't be reused
    Delphi 2989877 56 Series Female 12 GA Terminal 25 Pack [D56-2989877] - $10.25 : TheElectricalDepot.com!, Electrical Connectors and Much More!
    I went that route because I've replaced quite a bit of the wiring harness on my truck
    MEI 1055H is the complete pigtail
    MEI-MEI Wire Harness for Kenworth Trucks - 1055H-1055H
    Mine was melted when I got the truck six years ago. I didn't want to reinvent the wheel so I just replaced it with what was there. Add some conductive oxgaurd grease to keep the resistance low and maybe it will last a bit longer
    spsauerland and blairandgretchen Thank this.
  4. manleyman
    15
    15
    Oct 4, 2020
    All righty then!! I sure thank ya for the info, I had looked and called around to no luck.
    Many thanks.
  5. blairandgretchen
    13,926
    76,504
    Dec 9, 2011
    South west Missouri
    I’d be tempted to run larger guage wire to it and a bigger fuse, bypass the connector or modify the pins with a more solid connection.
    If it’s melted, at the plug, then I’m thinking a poor connection is creating heat.
    Rideandrepair Thanks this.
  6. tj379
    tj379 Light Load Member
    237
    226
    Nov 10, 2019
    ontario
    worst case could use spade connectors n do individually
  7. Rideandrepair
    17,545
    56,841
    Aug 8, 2015
    Freightliner has the same problem with bunk switch. The problem starts with the switch terminals getting loose on the switch. The arching causes the heat. Then melts the plug, once wires are touching in the plug, more heat. I thought It was the wiring getting hot, but after a year or two, had the same problem. Wires stay cool otherwise, with a new switch. Bottom line, cheap switch.
  8. Rideandrepair
    17,545
    56,841
    Aug 8, 2015
    D168275B-7248-4C31-8AC3-A9F4C603976A.png 4158B1A7-21F1-45F2-AC12-437751A515EF.png AB2A23A3-1B4D-43DD-89A9-9740CA03093D.png I had this problem on my last Truck, always thought it was a wiring problem, that took years to develop. Every junkyard Fld I’ve seen has the same problem. 2 yrs ago I replaced the plug harness and switch. I recently replaced the switch again, repaired and re used the melted plug for now. Nothing’s getting hot now. In my case at least, I’m convinced now, it all starts with the switch itself.
    manleyman, tj379 and RocketScott Thank this.
