Bolt hole in steer and chunks missing from trailer, should I replace?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GlassRoots, Jun 25, 2022.
  1. GlassRoots
    GlassRoots Bobtail Member
    13
    21
    Mar 7, 2015
    Should I replace all these? The chunks on the trailer tires is the only place I see that kind of damage. How can I avoid that in the future?
  3. Big Road Skateboard
    7,034
    39,818
    May 2, 2021
    If it didn't penetrate and that chunk isn't down to steel, run it
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You need a tire man to dismount that steering tire and inspect it to see if it went into the belts of that tire, poking it with a screw driver to see how far it went into tire is a bad idea?
  5. Judge
    91,563
    hmm.
    Run it til it blows... Tires are expensive and dangerous.
  6. Big Road Skateboard
    7,034
    39,818
    May 2, 2021
    Good thing he had his hard hat on.
  7. Judge
    91,563
    That’s one of the stupidest things ever.
    Had to wear a hard hat tarping a load before, when you bent over to pull tarp, off went the hard hat.
    once fell off a load of dry kiln lumber by stepping into a hole under tarp, and off the load and hit the ground.
    My glasses went one way, hard hat the other.
    so i crawled up by the drive tire and was leaning against it catching my breath, and this idiot from safety came by yelling at me to put my hard hat on.
    I called him every could think of and told him if I could’ve gotten up, i’d beat him half to death with my wench bar and see if his hard hat would save him..
  8. Rideandrepair
    17,531
    56,813
    Aug 8, 2015
    The steer is probably fine for now. They’re all pretty much worn out. Plan on buying new tires soon anyway.
  9. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    If they are all mounted on a trailer, they look fine to me. With trailer tires you don't need to be picky. As long as there's enough tread on them to be legal and they hold air. Probably good to go. That first pic of a steer tire, if it is on a steer axle, I'd get it checked out. Steer tires are no place to second guess or be cheap. Usually, once a steer tire is not in good enough condition to remain on a steer axle, you stickem on a trailer and run them for many thousand more miles.
  10. Rideandrepair
    17,531
    56,813
    Aug 8, 2015
    Makes me want to invest in a long hose, with a locking end, to stand back while airing tires on the Truck. Especially on my trailer. I buy them used quite a bit. No telling if they’ve been run flat, replaced because of being out of balance.
