Brokedown again thoughts????
Discussion in 'Experienced Truckers' Advice' started by TigerShark, Feb 9, 2016.
  1. TigerShark
    TigerShark Medium Load Member
    454
    329
    Nov 5, 2015
    Ok so cascadia Detroit diesel
    Driving down road
    Check engine light comes on
    Yellow warning light comes on
    Truck starts shaking when accelerater is pushed
    Won't go over 55 mph on flat ground
    Just my rpm and speedometer gages do this weird floating thing where needle just goes all over the place
    Oil press good
    Everything else solid except for my 2 gages and loss of power
    Truck is not governed
    Feels like those 6.o ford diesels when injectors go out
    But I can still idle truck although it is rough
    Sitting here now waiting at a repair shop till morning any ideas¥
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Gremlins,..
    Hurst
    TigerShark Thanks this.
  4. blairandgretchen
    13,929
    76,537
    Dec 9, 2011
    South west Missouri
    Shudder when it is mashed upon sounds like injectors or injector harness.
    That's just a wild hairy (had the same thing happen in a 2012 at 440k ) . . . guess.
    Grijon and TigerShark Thank this.
  5. blairandgretchen
    13,929
    76,537
    Dec 9, 2011
    South west Missouri
    And I'm hoping you don't own this truck, or you have a good sized maintenance account.
    Ours was a company truck, after 2 sets of injectors and 3 harnesses, we bid it farewell in Phoenix.
    I checked on it a few months later to find it had been a shop princess ever after.
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Had the same thing happen in my old truck, 2011 Volvo D13. Same shudder, same floaty needle thingy.
    It was just one injector though, so the engine wasn't totally gutless.
  7. kamen rider
    kamen rider Bobtail Member
    37
    30
    Feb 7, 2016
    Sparks Nevada
    Electrical voltage off? How's charging system also probably injectors or harness
  8. TigerShark
    454
    329
    Nov 5, 2015
    No is never own a freightshaker company truck
  9. TigerShark
    454
    329
    Nov 5, 2015
    Started truck this morning for mechanic check engine and all faults where gone he is looking at it now says could be a def issue or injector.....frigging truck. Seriously I can take a picture and video of what's going on and then pull it into a shop and it just goes back to normal........
  10. deep south
    deep south Light Load Member
    51
    22
    Jan 19, 2016
    fayettenam,GA
    look for a shop rag in the fuel tank,it will stay on the bottom when truck is off, it will get sucked up on the fuel line when running,blocking fuel causing mayhem.i was a wrench before i was a driver,and some people will bleed you dry with this trick.(KISS) keep it simple stupid .truck was ok b4 look for the simple repair.thats my motto.
    TigerShark and Lepton1 Thank this.
  11. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    If the injectors went bad it's the fault of their parents.
