Bungies...
Discussion in 'Flatbed Trucking Forum' started by TigerShark, Nov 30, 2016.
  1. TigerShark
    TigerShark Medium Load Member
    454
    329
    Nov 5, 2015
    Ok here's the deal I've only ever learned how to bungie a load using that typical v pattern dring through rail up to either same line dring or line below....but I've notice my tarp just blows a lot....
    I've seen maverick guys do this dring underneath to the rub rail and some guys going dring rubrail back to lower dring.....how can I make this tarp look sharp
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    I learn that bungee the sides does not really help make it look sharp, but making it tight. So really tight the front, back and some of the sides to make the center "stretch" tight.
    Klleetrucking, Lepton1 and TigerShark Thank this.
  4. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    Yes, gotta pull the corners tight and work it from there.
    kylefitzy and TigerShark Thank this.
  5. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Have you tried rolling the sides.
    TigerShark Thanks this.
  6. TigerShark
    454
    329
    Nov 5, 2015
    Always was taught to roll sides which does help. Ok I'll work on trying some new things out with the corners thanks guys
    Lepton1 and MJ1657 Thank this.
  7. Big_Red
    Big_Red Medium Load Member
    439
    989
    May 5, 2011
    Not active
    I always bungee to the highest row of rings I can reach. That usually stops the blowing, BUT watch your eyes...accident waiting to happen. And i do D ring to underside of trailer frame.
  8. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    rates are too low for a pretty tarp job...Like Johnny Mars once told me "Man,The Stuff underneath the tarp gets more wet than on top"
  9. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    BINGO! Pin down two corners on on end and pull the other end tight.
    I think the Maverick thing you're talking about is using on bungie per d ring. hook the strap to the d ring run it through the rub rail and pull it as far as you can and hook it to the rail.
    Macneil Thanks this.
  10. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Pinch the tarp at the rail with your left hand, then gather the excess below with your right and shove up underneath that fold you created with your left hand. Should help create better tension on the tarp to keep it from flapping.
    Post some pictures of your tarp jobs for some tips.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Also triple the number of bungees. Add more until tarp quits flying.
    Keep a roll of twine rope. A few thousand feet of the stuff woven block and tackle style will hold her until the ice freezes everything into place. Use a hammer to bust ice, then blade to slice.
    If you go into a high wind warned area, wait a while. Preferably overnight.
