Bunk heat laws?
Discussion in 'Experienced Truckers' Advice' started by king v, Jan 28, 2018.
  1. king v
    king v Light Load Member
    222
    149
    Jun 21, 2015
    Im in IL, load is going to MN. Its gonna be 4 degrees tonight. Ive been with this company for 5 weeks and Ive had no bunk heat when shutdown. Truck does not idle. It's 18 degrees now and still does not idle. 32 degrees is freezing and my sensor will only supposedly allow idling if it get below 20. I have a parksmart heater, already lost a week in the shop with no change. The managers know and I still got the run around about a hotel room after my delivery. I haven't slept at all today because I had a pickup mid day and it was still too cold to take my foot off the clutch. It's 8:50pm, i roll out at 11 to deliver at 4. How is this legal? They chose this after I gave my 2 weeks notice.
    Steel Dragon Thanks this.
  3. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    What truck are you in? There should be a maintenance idle that you can set so it won’t shut down.
    Steel Dragon and king v Thank this.
  4. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    Jam something on the pedal to keep from shutting off. Idle it all night
    Grubby, jammer910Z, 201 and 6 others Thank this.
  5. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Try releasing the tractor brakes.
    jammer910Z, king v and HalpinUout Thank this.
  6. king v
    222
    149
    Jun 21, 2015
    There's no way around it. And i havent yet found anything to jam between the clutch and the seat that will stay.
  7. king v
    222
    149
    Jun 21, 2015
    Released... Waiting.
  8. king v
    222
    149
    Jun 21, 2015
    2014 cascadia. They revamped the whole idle thing last year though. Cruise control trick doesnt work anymore.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Take it out of gear, set your tractor brakes and jam a stick or what ever between the seat and the throttle pedal so that it thinks its not idling... Then it won't shut down. Idle it all night and run your heater. When they complain about idle time you tell them to fix the #### bunk heater and you will consider not idling all night.
    Brickwall, Grubby, mhyn and 4 others Thank this.
  10. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    I wonder can you take a load lock and press it up against the ceiling and then the other end on the peddle? Not sure if they are to long though? Assuming you do Van or reefer.
  11. king v
    222
    149
    Jun 21, 2015
    Still shuts off.
    DTP and Steel Dragon Thank this.
