Can I keep going?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, Sep 30, 2016.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    This happened while adjusting my tandems after scaling out. 1. Can I keep going if I hang it back up temporarily with zip ties or a small chain? 2. Can I keep going?
  3. austinmike
    132,680
    I wouldnt -
    tucker Thanks this.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    And you hold an CDL? That is OOS anytime, anyplace.
    bzinger, KB3MMX, crb and 5 others Thank this.
  5. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    No one asked for a smart ### reply. If youre not going to contribute some possible solution or positive response please stay the #### out of my thread ####o.
    slickWillie1980 Thanks this.
  6. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
  7. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    Isn't that wheel locked up right now?
  8. jackhartjr
    jackhartjr Light Load Member
    158
    128
    Jun 5, 2011
    Hickory, NC
    I didn't think it was a smart ### answer! More like a ridiculous question!
    Any idea what's going to happen with that brake when it engages several times?
    Now if you had asked if you can tie it up long enough to get it to a shop, I would say yes!
    BigPerm, KB3MMX, crb and 4 others Thank this.
  9. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Depends on who you work for.... there's a few possibilities.
  10. Ridgeline
    22,694
    121,912
    Seriously you are asking this?
    This needs to be fixed, and if you go down the road, and this locks up causing an accident, do you think they won't see this post and you lose a lot because of something that you should know the answer to.
  11. scottied67
    10,826
    12,675
    Mar 14, 2010
    california norte
    What you can do is back it off all the way or cage it and tie it up so you can get to a shop otherwise will have to sit onthe side of the road with that wheel's brakes completely locked up.
