Chaining up drives
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Dec 17, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I see trucks chain up most rear set of drives (from cab) is it proper to chain that set or forward set of axles and why?
  3. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    I always chain the front axle if I'm just throwing 1 set. Why? Because that's the set that gets the power first. Does it matter idk Old hand I looked up to and gave me a lot of great advice when I was starting out always said that so I still do it to this day
    BUMBACLADWAR Thanks this.
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Chaining all drive wheels gives the best chance of not losing traction but one axle can help some.
  5. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    The requirements / possibilities: wp_ss_20161029_0002.png
    207nomad, QuietStorm and mitmaks Thank this.
  6. Pnwtrucker
    383
    821
    Nov 5, 2016
    1 axle with 3 railers or triples whatever you prefer to call them is always better then 2 axles with singles. From my experience. Singles are a waste of time unless your putting them on your steer axle
    scottied67 Thanks this.
  7. mitmaks
    2,586
    2,102
    May 16, 2014
    If i was chaining up one set of drives should I do front one as my trainer told me. Ive seen quite a few trucks chained up only rear set of drives. Just wondering whats thr reason for that if any? Probably easier to get chains around fear set of duals?
  8. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    The only reason is the rear axle is easier.
    TequilaSunrise Thanks this.
  9. Pnwtrucker
    383
    821
    Nov 5, 2016
    I like to chain the front set of drives if only chaining one drive axle. The front drive axle receives the power essentially first. Yes I know both basically get it at the same time. But I think front axle gives better traction and less spinning if starting out in a tough spot
  10. KillingTime
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    They'll also be the ones that kick-out on you.
  11. Pnwtrucker
    383
    821
    Nov 5, 2016
    Ok I've thrown a lot of chains and I mean a lot. If the front axle is chained how could that let the rear axle "kick out"?
