clogged doser isx
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sheamus cavanaugh, Jul 19, 2015.
  1. sheamus cavanaugh
    sheamus cavanaugh Bobtail Member
    6
    Why dose the doser keep plugging up? 09 isx. Average 2500 mi. per check engine light. $120 per light for forced regen is getting old.
  3. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    If the dozer has OVER 250k on her its time to replace the injector. They dont last to long past that before giving issues. Some good injector cleaner ran thur the system may help also as it feeds off ur fuel tanks.
    flood Thanks this.
  4. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    And to think instead of paying 120 a week to do a forced regen you could have replaced the injector the egr diff pressure sensor imap sensor and the egr pressure sensor for about 700 and had a sweet running isx.
    MM71 Thanks this.
  5. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    The guy told me to do a parked regen at the end of every day when the truck is nice and warmed up from running all day. About half the time it will do a parked regen and other times it won't because it just did a passive regen up on the road.
    Also if you idle a lot that will clog it up too. If you must idle, bump it up to 1000 rpm so the injector can do its job better.
  6. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    Get a laptop, cable, and insight software. So that you can do the forced regen yourself. Check out rawze on you tube. Lots of good instructional video's on how to diagnose, clean, remove, and replace emissions components on an ISX
  7. sheamus cavanaugh
    6
  8. sheamus cavanaugh
    6
    Thanks for the ideas. Have cleaned it several times. Last 2 times went around 2500 mi. And to think no one lncluding shops made any helpful sugestions.
  9. sheamus cavanaugh
    6
    Won' do a manual unless light to do so is on.
  10. Coyote302
    Coyote302 Light Load Member
    86
    71
    May 9, 2014
    LA(lower Alabama)
    My experience with an 09 isx proved cleaning the doser to be a waste of time and money, just replace it.
    I had more than one shop point to the doser for a code reading for DOC face clog. If you have over 500k miles, it could need a DOC.
  11. Fajo
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    When my truck is idling it actualy disables the dozer, if it needs a regen it will pop a light and ask me to do a parked. But it wont do a passive why sitting there idling.
    ISX 450 Cummins
