Cooking a Steak while Driving
Discussion in 'Food & Cooking in the Truck | Trucker Recipe Forum' started by Midlife Trucker, Aug 29, 2020.
  1. Truckers Report Jobs
  2. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Nope not going to watch. It will be a crime against bovine kind. Steaks MUST be flame kissed over coals not tortured by engine cooking.
  3. Midlife Trucker
    Midlife Trucker Light Load Member
    281
    288
    Dec 3, 2011
    Shady Dale, GA
    The smoke from a grill might get me a DOT inspection
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Ive always thought it would be kinda cool to mount a small smoker in a tool box on the catwalk especially now that a couple brands are 12v powered. Hahahaha
  5. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    actually a lot of restaurants use this method, then seer it on an open flame. It’s used for the lunch and dinner rush, hell even more restaurants use a pan and not even on a flame.
    unless it’s cooked by the eater I don’t trust restaurant food.
  6. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Wood pellets are not hazmat and they sell a small pellet grill. You'd need an Apu or inverter though.
  7. Midlife Trucker
    281
    288
    Dec 3, 2011
    Shady Dale, GA
    I’ve seared using a Searzall and a torch. I’ve seared using a cast iron skillet and my single burner. And I sometimes wear using the Galanz oven. Each has its benefits. At home, I often use the grill at a high temperature. Using sous vide as a cooking method works well in a truck. Often we do not know when we will stop for the break, and with sous vide, cooking too long doesn’t hurt the meat.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Done right i have no qualms with pan seared. If i have a thinner cut NY strip i'll do it on the pan. The pan has to be really clean and nice and hot. Med hi heat, a few min on either side and mmmm
  9. WIlee81
    WIlee81 Light Load Member
    176
    248
    Aug 19, 2019
    SE Louisiana
    I just season and throw them in the oven set at 280 and cook till the internal temp is where I want for a given doneness (135 for medium), then sear them in the cast iron on high temp. Searing takes like 3 minutes total per steak.
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Wrap it in foil with spices and onions and mushrooms and throw it on the exhaust manifold.
    You must have your cooking calibrated by mileage though
