Coolant and water question ??
Discussion in 'Ask An Owner Operator' started by GYPSY65, Sep 4, 2024.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    Just had a new mx13 long block installed
    long story short
    The shop used the original hoses etc
    And one of the radiator hoses got a pretty good leak in it
    I had to use about 4 gallons of tap water to get me to where I could get off tye road and change it out
    then put a new reservoir tank on and added about 4 gallons of fresh coolant
    that said
    I’m not concerned with the freeze temp level as it should be pretty close to the level of protection it was before this
    But
    Is there any concern in the tap water and interior damage or should I flush the system?
  3. 062
    062 Road Train Member
    6,327
    33,967
    Oct 20, 2013
    Probably depends on the minerals in the water.
    @Goodysnap
  4. blairandgretchen
    13,930
    76,553
    Dec 9, 2011
    South west Missouri
    Personally I’d dump the lot and start fresh if it’s a new block.
    Lav-25, GYPSY65, Oxbow and 7 others Thank this.
  5. Siinman
    Siinman Road Train Member
    5,513
    14,173
    Mar 5, 2017
    Kansas City, MO.
    Because it is cheap insurance I would dumb the old and put in the new. Not much money to do so considering you just put new block in. No reason to take a chance.
  6. Ruthless
    Ruthless Road Train Member
    9,173
    91,073
    Aug 28, 2010
    The City.
    that and put new hoses on.
    There is a couple reasons that you’re supposed to use coolant with distilled water and not tapwater, Seems pretty shortsighted to me to save $30 on coolant and have bubbles beat a hole through your cylinder wall.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Depends if you used 100% antifreeze or the 50/50 mix. Which is more commonly sold.
    The 100 would get you there. The 50 would still leave you on the weak side.
    Rideandrepair Thanks this.
  8. Ridgeline
    22,720
    123,266
    Why would the shop used old hoses, always go with new, they should know better.
    GYPSY65 and Rideandrepair Thank this.
  9. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Industry standard is to use distilled water if you’re adding or mixing with concentrated antifreeze. Adding well water is probably the worst possibility due to the high iron/metal content. The short term effects when added to coolant are very minimal. You most likely added premix ELC which wouldn’t have increased the freeze point much after adding 1/3 of the system capacity with straight water. The only way to know is to test it. We flush systems with well or tap water every day, but always drain completely and fill with new coolant.
    Play it safe and dump it. Fill it with new premix.
    If the engine was replaced under warranty it is hard to get all new hoses covered. Needless to say they could have let you know they were in bad shape and given you the option to replace.
    This was a warrant long block right?
    GYPSY65, Siinman, 062 and 1 other person Thank this.
  10. Rideandrepair
    17,551
    56,868
    Aug 8, 2015
    Get something like Final Charge. that already has additives needed to fight electrolysis/corrosion, anti foaming agents to fight cavitation, It’s pricey, shop around. Concentrate is available. It’s on line or usually special order at some of the auto parts stores. If money’s a concern. I’d get 6 gallons, and 6 gallons of distilled for a 10 gallon system. Mix 50/50. Premix what’s left leftover for topping off. Might save about $100.
    GYPSY65, Siinman and blairandgretchen Thank this.
  11. blairandgretchen
    13,930
    76,553
    Dec 9, 2011
    South west Missouri
    I used it in the N-14. The red stuff. For some reason I found it more commonly at Flying J.
    The S60 has green coolant in it, I asked my mechanic about swapping it out, he was 50/50 on the idea, so I kept the green. It is arguably easier to find.
    GYPSY65, Oxbow, Siinman and 1 other person Thank this.
