Coolant Pressure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fishell Trucking, May 26, 2015.
  1. Fishell Trucking
    Fishell Trucking Light Load Member
    128
    33
    Jan 11, 2011
    Raymond Montana
    Ok tonight after my truck has been sitting for 4 days I was checking things out for tommorow and noticed that my coolant line on the top of the radiator felt presured up. So I checked the coolant and as I opened the rad. cap it did indeed have quite a bit of psi. Is this normal? Have I not noticed it before? I don't have any coolant comeing out the overflow line. I have did the bottle test and get no bubbles on the overflow line either. I just thought after sitting for that many days and not beeing ran the psi. wouldn't have been built up like that. I have had this engine overhauled and the counterbores cut I would hope I am not heading down that road again. Oh ya and the aircompressor has less than 140,000 miles on it. The engine and upgrades are listed in my sig. Thanks
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    I'd think that's a good thing ... No pressure loss means it can't possibly be leaking or equalizing anywhere right? There's supposed to be some psi under the cap. But after sitting a few days I would of figured it had slowly depleted ...
  4. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    You probably last closed the cap at a lower elevation, colder temperature, &/or higher barometric pressure -- just like a bottle of soda or shampoo...
  5. blairandgretchen
    13,876
    76,138
    Dec 9, 2011
    South west Missouri
    The above 2 replies would have been my guess too - no leaks= tight system, and elevation or temperature.
  6. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    It is definitely a good thing holding pressure as you described. It you checked it on a warm day or with the sun on the hood it may well build a little pressure.
