Cornering at night?
Discussion in 'Questions From New Drivers' started by ichudov, Nov 24, 2019.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    I am 48. I am not really a new driver, I had a CDL since 2016, but I drive 99% during the daylight.
    This winter season, I realized that if it is really dark, and I am making, say, a right turn, it is very hard to see what is going on with the back of the trailer. At this point I sort have an idea how to turn most corners, but still I am slightly uncomfortable with the lack of visibility.
    How do people deal with this issue? Any brighter turn signals or something to light up the area better?
    Backing up is even worse, but overall I do not back up much in the darkness so it is not as much of a priority, I drive rgn/flatbed/stepdeck.
    truckdriver31 and D.Tibbitt Thank this.
  3. D.Tibbitt
    156,013
    If u got work lights on the backside of ur truck then turn them on .. Also thats where chicken lights come in handy... But i have the same problem. Sometimes just got to take note of whats on the corner before u start turning and make sure if u run it over its not going to damage anything
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i "just did it"...
    if you know how to make turns in daylight, you should be able to make them in the dark.you take them just as wide...??
    as for backing up, i tried several things, like a flashlight on the ground, or on the loading dock platform. i just used my 4 ways, they were bright enough for me to see the docks.
    once you make a right turn, in broad daylight or darkness of night, you are blinded by what's happening anyways...what do you do then.???
  5. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    there should be a marker light at the end of your trailer. Use that as reference when you're turning.
    As for backing, if it's dark i use a bright flashlight to point backward (flatbed) probably can tie it to the dot bumper in a van.
  6. Troy_
    Troy_ Road Train Member
    1,226
    9,253
    Dec 13, 2017
    Roma, Alberta.
    convex mirrors are handy
  7. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,529
    Mar 17, 2017
    Just swing it wide, it’s not like the curb is gonna jump out and get you at night.
    Woodys, Ironmyke, AModelCat and 9 others Thank this.
  8. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Convex mirrors and marker lights on the side of the trailer. If I have any doubts I just swing it as wide as I can.
  9. Hazmat Cat
    Hazmat Cat Medium Load Member
    636
    1,778
    Oct 18, 2019
    When in doubt, Whip it out.
  10. truckdriver31
    6,998
    8,362
    Sep 18, 2013
    dont back up with the fourways on.
    ichudov Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    Swing it wider then normal.
    I have a couple of intersections going to or leaving the plant where the truck is parked. They're not designed for semis. You really gotta watch your arse with the 4 wheelers though cuz they LOVE to drive right through your turn. They could care less about the amount of space needed to avoid the curb and fire hydrants.
    buddyd157, D.Tibbitt, ichudov and 2 others Thank this.
