Cruise problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cat 03, Nov 28, 2023.
  1. cat 03
    cat 03 Bobtail Member
    24
    8
    Mar 22, 2013
    I have a 97 pete 379 my cruise is kicking off. I replaced the switch at the clutch arm last year. Could it be bad again if so is there a cheaper place to get them other than peterbilt
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,833
    75,714
    Dec 9, 2011
    South west Missouri
    The clutch arm linkages may need replacing, could be the brake switch too. Might want to set it to high idle with the cruise, and start poking around clutch linkages , brake pedal, wiggling cruise on/off switch etc.
    InTooDeep Thanks this.
  4. cat 03
    24
    8
    Mar 22, 2013
    Thanks I had not thought of that
