Cummins n14 cam position sensor?
Discussion in 'Ask An Owner Operator' started by Fld1201994, Dec 21, 2021.
  1. Fld1201994
    Fld1201994 Bobtail Member
    29
    15
    Jan 25, 2020
    I replaced the cam position sensor about 5 months ago what are the chances of it going bad again ?
  3. blairandgretchen
    13,930
    76,546
    Dec 9, 2011
    South west Missouri
    Usually good for for a few years.
    What's wrong?
  4. Fld1201994
    29
    15
    Jan 25, 2020
    Cranks strong but doesn’t start, at first the fuel solenoid has power to it then after a few cranks it doesn’t anymore, I tried putting a 12v contactdirectly on to the solenoid but it still doesn’t start
  5. Fld1201994
    29
    15
    Jan 25, 2020
    i feel that maybe the ecm it’s going into an auto protect
    77fib77 Thanks this.
  6. ChevyCam
    ChevyCam Light Load Member
    269
    402
    Mar 4, 2018
    I carry a spare EPS sensor always. 6-12 months is normal life span in my opinion they do not make them like they use to. Also opt for OEM sensor and not the cheaper ones found on amazon and ebay as they are not of the same build quality as OEM.
    I have had one fail without warning only 3 months after replacing it.
    Good luck.
  7. abyliks
    abyliks Road Train Member
    4,110
    9,670
    May 2, 2010
    ludlow MA
    Oem or Chinese? I usually keep a spare one under the bunk
