Cummins overhead.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr Bob, Apr 3, 2024.
  1. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    Old Cummins came in and needs overhead set. What are the injector specs? 11573369 NTC444
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    As best I recall they came with a little L shaped tool bolted to the water rail. Slide that in above the injector and adjusted like a top stop. That was super seeded by torque method which I prefer. All rockers on the same cylinder adjusted at the same time. I was questioning the injector torque that I recalled and searched the net which brought me back to TR. Search block top right ( 444 , STC injector overhead adjustment and such). Pup answered most all of it. We were torqueing 365's to 110 inch pounds as I recall. There were many of them and few 444's here.
    We were screwing around with them trying to get a little bit more. Tighter gained no power and looser made them smoke like a late model NTC 400 on cold start. They also pulled no better. If you find no specs for your CPL I would go with Pups 90 inch Lbs. If it smokes more than before go to 105 per Pup.
    A friend of mine worked a Cummins. I know the local shop went to the torque method and he is the one that told me how the do that.
    Double check all that as it has been a long time.
  4. Inderjit
    Inderjit Heavy Load Member
    767
    732
    Sep 17, 2017
    The L shaped tool is no longer used. Cummins said to use the outer base circle method to set them using a torque wrench on the injectors.
    The valves are .014" for intake and .027" exhaust. Set the injector to 80 InLbs.
