DEFinately unsure about it
Discussion in 'Ask An Owner Operator' started by TruckerVinny, Jan 24, 2019.
  1. TruckerVinny
    TruckerVinny Medium Load Member
    375
    253
    Dec 10, 2015
    I drive a company C15 pre-emissions 13 speed and really like it. My last assigned truck was a '15 Pete with emissions. I had nothing but problems the DEF. Now I'm looking to move forward into ownership and am trying to avoid it. Does every truck go through difficulty at 3-500k with this BS system?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    It IS a BS system and I aint never touched one yet. Be ###### if I do.
    I would be idling at 1500 set to make sure the thing wont go into regen or something stupid inside the GWB the following morning.
    D.Tibbitt and OldeSkool Thank this.
  4. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    I haven’t had issues out of the after treatment. I’ve had two higher mileage DEF trucks. One did well and the other was a fleet truck with high idle time. The idle time will clog the EGR components under the hood. As long as you follow the maintenance schedule from the manufacturer and don’t idle a lot, they work fine.
    PE_T, larry2903 and Tb0n3 Thank this.
  5. RockinChair
    RockinChair Road Train Member
    5,351
    14,271
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Who do you drive for, and what brand of truck are you in?
  6. Ridgeline
    22,717
    123,129
    No, if every truck did, a lot of companies would be out of business.
    larry2903 Thanks this.
  7. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I had a 2012 freightliner and I spent upwards of $16k last year on def alone... motor messed up and I got a kw now pre def... It's a C15 cat acert twin turbo 475 hp. Runs great.. so if you can find something pre def I would definitely go for it.
    There is a group on Facebook called big rig buy, sell, and trade. They got guys selling pre def trucks all the time. Enjoy it while you can cause if the govt has their way by 2022 you wont be able to have any truck on the road 2003 or older...
  8. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,647
    Oct 5, 2012
    Earth
    You had a lemon and decided to go with an acert? Aren't they also known for their problems? 2012 they were just figuring it out and they've improved a lot. Hopefully the law restricts the highest polluting trucks because we're really getting screwed with climate change.
  9. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I actually like an acert... I really enjoy this truck has all the power I need. It had an overhaul when I bought it. I haul dry van and my loads are around 18k loads all the time.. so easy running...
  10. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    I wouldn’t know so I’m only asking. Don’t large companies buy new trucks and filter them out before they are liable for out of warranty repairs? So I would think yes, an owner operator should avoid a used higher mileage epa truck unless they want to deal with problems
  11. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    Idling is what kills these trucks. I don't let drivers live in the truck for those reasons. We do a lot of idling to load and unload so idling on your ten hours of just leads to problems
